[Mapbender-users] Antw: Re: Legend
    jt at mapmedia.de
    jt at mapmedia.de
    Wed Jan 13 01:55:15 PST 2016
Hello Gerhard,
seems more to be an apache-problem. Is the
directory-name of the mapbender-installation after upgrading still the
same? Or do you change it from ...../mapbender3.0.4.1 to
.../mapbender3.0.5.2. If you do so, you have to change the
alias-configuration of apache (see
http://doc.mapbender3.org/3.0.4/de/book/installation.html#download) and
restart the service. Its easier to use a directory-name like
mapbender3/.
Jörg
On Wed, 13 Jan 2016 10:33:05 +0100, Gerhard Mocza
wrote:
> Hi All !
> So i tried out 3.0.5.2 on my developing machine
and i think, i found out right proxy-configuration. Result is:
Legend-Symbols will be displayed on the side-pan !
> So i wanted to
upgrade from 3.0.4.1 on my production machine, too, but:
> i could it
not get to work - maybe i have forgotten something, but i think i made
all the stuff as on the dev-machine !
> When i want to display my
mapbender-applicationspage xx.xx.xx.xx.xx/mapbender3 on a webbrowser,
i'll get error-message: _the requested page "/mapbender3/" could not be
found._
> when i go back to 3.0.4.1, all is working wonderful (except
the legend-symbols).
> _ _
> so here is my question:
> the only
thing, which was not working at upgrading, was this SQL-command (which
was recommended for upgrading to 3.0.4.0, when mapbender3 is running on
a postgresql-DB):
> _ALTER TABLE fom_profile_basic DROP CONSTRAINT
fom_profile_basic_pkey;_
> Error-Message is: relation
"fom_profile_basic" does not exist.
> Has anyone a glue ?
Mapbender3-directory has already writing-permit for www-data !
> Thanks
and regards
> Gerhard
> Gerhard Mocza
> Institut f. Vermessung,
Fernerkundung und Landinformation
> Peter Jordan Str. 82
> A-1190 Wien
> Tel.: 47654/5117
> email: gerhard.mocza at boku.ac.at
>>>> Armin
Retterath 22.12.2015 11:50 >>>
> hi gerhard,
> choose the
ows_proxy3_host and ows_proxy3_port for your proxy and set
ows_proxy3_noproxy to localhost. this may help for 3.0.5.2 ;-)
> regards
from germany
> armin
> On 22.12.2015 11:47, Gerhard Mocza wrote:
>> Hi Astrid !
>> Thank You for your response.
>> I' ve installed
3.0.5.2 at my developing machine, but for my legend-issue, this was not
the solution.
>> Difference between 3.0.4.1 and 3.0.5.2 is entry
"OWSProxyConfiguration" in parameters.yml, right ?
>> Which entry is
right for ows_proxy3_host and ows_proxy3_noproxy ?
>> kind regards
Gerhard
>> Gerhard Mocza
>> Institut f. Vermessung, Fernerkundung und
Landinformation
>> A-1190 Wien
>> Tel.:
47654/5117
>> email: gerhard.mocza at boku.ac.at [1]
>>>>> Astrid Emde
[2] 21.12.2015 08:43 >>>
>> Hello Gerhard,
>> I had a look at your
log file. Look like in your GetLegendGraphic zu
>> have encoded parts
(request=GetLegendGraphic%26version=1.3.0%26format=image/png%26layer=0&_signature=106%3A6ViVPx-E8aW020AS215KMHnYRBA)
http://../arcgis/services/AKK/acc_b_wr_neustaedter_pforte01_v02/MapServer/WmsServer?request=GetLegendGraphic%26version=1.3.0%26format=image/png%26layer=0&_signature=106%3A6ViVPx-E8aW020AS215KMHnYRBA
[3]
>> Mapbender3 encodes the Request again which may cause th
error.
>> Try Mapbender 3.0.5.2 . The problem should be solved with
this version.
>> Astrid
>> Am 2015-12-11 14:55, schrieb Gerhard
Mocza:
>>> Hi Astrid !
>>> Thanks for quick response.
>>> First: the
connection from the inside-GIS-Server to the world is
>>> unchecked by
myself, but it was tested today positive with a friend
>>> (in the
outside world).
>>> So it was surprising for me, to put a check to PROXY
in the
>>> WMS-Instanz of the service and the connection is working
already
>>> without configuration of proxy in parameters.yml.
>>> I am
using mapbender 3.0.4.1.
>>> I am sending screenshots of the legend
(with proxy: bottleneck1 and
>>> without proxy: bottleneck2) and the log
of the apache-access (first 15
>>> lines for application bottleneck1
with proxy checked and spoiled
>>> legend, last line for application
bottleneck2 with proxy unchecked and
>>> working legend).
>>> kind
regards
>>> Gerhard
>>> Gerhard Mocza
>>> A-1190
Wien
>>> Tel.: 47654/5117
[4]>>> Astrid Emde
>>> [5] 11.12.2015 13:51 >>>
>>> Hallo,
>>> when you print the requests are send from the server. So your
server
>>> must reach the services and know himself.
>>> Please
configure the proxy in parameters.yml
http://doc.mapbender3.org/en/book/installation/configuration.html#parameters-yml
[6]
>>> [6]
>>> And maybe define ows_proxy3_noproxy.
>>> Have
a look in your logfiles to find out which requests failed and
>>> what
is the error message.
>>> Can you send a map and a getLegend
request to compare the two?
>>> Do you use Mapbender3 3.0.5.2? We
had an issue with the legend in
>>> earlier versions.
Astrid
>>> Am 11.12.2015 12:38, schrieb Gerhard Mocza:
>>> Hi
All !
>>> I have already successful installed a mapbender-application,
which
>>> request WMS-Services from an Server inside our local net,
seperated
>>> through a firewall.
>>> Outside the local net in the
DMZ-Zone mapbender is working with
>>> legends, generated from the
layers of the wms-service.
>>> Recently i found out, this configuration
is working well with the
>>> proxy-function, but legends are not
displayed anymore. When i turn off
>>> the proxy-function, inside the
local net i can use wms from our
>>> GIS-Server with displayed layers in
the legend (of course not outside
>>> the local net) - turning on the
proxy-functions will disturb
>>> displaying layers in the legend.
Has anyone seen this too ?
>>> Thanks und regards
>>> Gerhard M
Gerhard Mocza
Landinformation
>>> A-1190 Wien
>>> Tel.:
47654/5117
>>> email: gerhard.mocza at boku.ac.at [7]
>>> Mapbender_users
>>> Mapbender_users at lists.osgeo.org [8]
http://lists.osgeo.org/mailman/listinfo/mapbender_users [9] [1]
>>> Mit freundlichen Grüßen
>>> Astrid Emde
GIS-Consultant
>>> FOSS
Academy Winterschule 2016
>>> Alles Wichtige zur Erstellung einer GDI in
nur 5 Tagen!
>>> http://www.foss-academy.eu/winterschule_2016 [10]
[2]
>>> Astrid Emde
>>> WhereGroup GmbH & Co.KG
>>> Eifelstraße 7
>>> 53119
Bonn
>>> Germany
>>> Fon: +49(0)228 90 90 38 - 19
>>> Fax:
+49(0)228 90 90 38 - 11
>>> astrid.emde at wheregroup.com [11]
www.wheregroup.com [12] [3]
>>> Folgen Sie der WhereGroup auf
twitter:
>>> http://twitter.com/WhereGroup_com [13] [4]
Amtsgericht Bonn, HRA 6788
Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284 [14]
[5]
>>> Signierte und/oder verschlüsselte Nachrichten sind sehr
willkommen
>>> Signed and/or encrypted mail is highly appreciated
>>> Links:
>>> [1]
http://lists.osgeo.org/mailman/listinfo/mapbender_users [15]
>>> [2]
http://www.foss-academy.eu/winterschule_2016 [16]
>>> [3]
http://www.wheregroup.com [17]
>>> [4] http://twitter.com/WhereGroup_com
[18]
>>> [5]
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284 [19]
[6]
[20]
Mapbender_users mailing list
[21]
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users [22]
>> Astrid Emde
GIS-Consultant
>> FOSS
nur 5 Tagen!
>> http://www.foss-academy.eu/winterschule_2016 [23]
>> Astrid
Emde
>> Eifelstraße 7
>> 53119 Bonn
Germany
>> Fax: +49(0)228 90 90 38 -
11
>> astrid.emde at wheregroup.com [24]
>> www.wheregroup.com [25]
>> Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com [26]
6788
>> Komplementärin:
>> WhereGroup
Verwaltungs GmbH
>> vertreten durch:
>> pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284 [27]
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>> Mapbender_users
>> Mapbender_users at lists.osgeo.org [28]
http://lists.osgeo.org/mailman/listinfo/mapbender_users [29]
>> Mapbender_users
>> Mapbender_users at lists.osgeo.org [30]
http://lists.osgeo.org/mailman/listinfo/mapbender_users [31]
Zentrale Stelle Geodateninfrastruktur
> Rheinland-Pfalz
> LVermGeo-RP
> Von-Kuhl-Straße 49
> 56070 Koblenz
> 0261/492-466
armin.retterath at lvermgeo.rlp.de [32]
> http://www.geoportal.rlp.de
[33]
Links:
[1] mailto:gerhard.mocza at boku.ac.at
[2]
mailto:astrid.emde at wheregroup.com
[3]
http://../arcgis/services/AKK/acc_b_wr_neustaedter_pforte01_v02/MapServer/WmsServer?request=GetLegendGraphic%26version=1.3.0%26format=image/png%26layer=0|+|amp|+|_signature=106%3A6ViVPx-E8aW020AS215KMHnYRBA
[4]
[5]
[6]
[7]
[8]
mailto:Mapbender_users at lists.osgeo.org
[9]
[10]
[11]
[12] http://www.wheregroup.com
[13]
[14]
[15]
[16]
[17]
[18] http://twitter.com/WhereGroup_com
[19]
[20]
[21]
[22]
[23]
[24]
[25] http://www.wheregroup.com
[26]
[27]
[28]
[29]
[30]
[31]
[32]
mailto:armin.retterath at lvermgeo.rlp.de
[33] http://www.geoportal.rlp.de
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160113/e000f536/attachment-0001.html>
More information about the Mapbender_users
