[Mapbender-users] Mapbender (2.7.4): Digitizer functionalities
Armin Retterath
armin.retterath at gmail.com
Fri Jan 22 11:30:46 PST 2016
hi lukas,
the wfs-t digitize module can handle only flat (simple) featuretypes. if
you have a complex model, it is possible to flatten it by using database
rules and views. this is quiet easy. we use the module to digitize many
different featuretypes in distributed wfs-t. the client itself can be
defined very comfortable (dropdown menus, datepickers, mandatory fields,
the documentation for the configuration in german language is quiet better
than in english ;-) :
https://www.mapbender2.org/WFS_Konfiguration
(we use geoserver and tinyows as wfs-t server)
the digitize module parses the describefeaturetype response from the wfs
and therefor knows the datatypes of the attributes of the featuretype. the
special options to fill the attributes (e.g. datepicker) are configurable
at the wfs-configuration in form of simple templates.
we plan to integrate the option to reference skos based classification
schemes as codelists for special attributes in near future. at the time you
have to define existing codelists as html select option elements by hand.
if you have further questions, don't hesitate to ask - i think i can help
you :-)
best regards from germany
armin
2016-01-22 16:17 GMT+01:00 lukas.bollack <lukas.bollack at naturnetz.ch>:
> Hello Mapbender mailing list!
> I would like to use mapbender (2.7.4) to digitize new features in a postgis
> database via wfs-t. I've played around with the digitizer module but it
> seems to be very basic. If I have a postgis layer with a couple of
> attributes and maybe even some secondary keys which lead to other tables -
> can the digitizer handle this? Does it know which attributes there are and
> what kind of data the user is allowed to put in there, or do I have to tell
> this to the module first? If I have to - how do I do this? I couldn't find
> much about it in the official documentation.
> It would be great if someone could shed some light on this!
> Thanks!
> Lukas
> http://osgeo-org.1560.x6.nabble.com/Mapbender-2-7-4-Digitizer-functionalities-tp5246772.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160122/8482ec86/attachment.html>
More information about the Mapbender_users
