[Mapbender-users] Adjust your PHP parameters, if you use WMS services with many layers
Axel Schaefer
axel.schaefer at wheregroup.com
Wed Jul 20 04:59:42 PDT 2016
Hi.
We had the issue https://github.com/mapbender/mapbender/issues/414 and
recognized a direct connection between the error that you cannot save a
WMS instance and the number of options that you can set there.
At a specific layer you couldn't check a checkbox and the form was
invalid (a token was not part of the form therefore it was invalid).
However the number of checked checkboxes was the hint: If they are some
handful higher, the form wasn't saved.
The PHP-parameter for that is the "max_input_vars". If you experience
that problem, put it to a higher value. In my php.ini it was commented
out and I set it to 2000. Depends a bit on the number of layers my WMS
has. ;-)
HTH and HAND
Axel
Axel Schaefer
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 23 (neue Durchwahl!)
Fax: +49 (0)228 / 90 90 38 - 11
www.meldemax.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
