[Mapbender-users] Error when trying to make a custom template
    Andreas Schmitz
    andreas.schmitz at wheregroup.com
    Mon Jun 13 05:47:28 PDT 2016
Uwe Seher wrote:
> I am trying to create a own template for mapbender3 v 3.0.5.3. At the
> moment i have downloaded the sample code and go through the description.
> The tree for the DemoTemplate is in $INSTALL_DIR/mapbender/src/ on the same
> level as the Mapbender-Dir. All files and dirs are owned by the
> webserver-user.
> When i get to this point in the tutorial:
> app/console assets:install web --symlink --relative
> this error appears:
> PHP Fatal error:  Class 'Workshop\DemoBundle\WorkshopDemoBundle' not
> found in /srv/www/htdocs/mapbender3-3.0.5.3/app/AppKernel.php on line
> 40
this means that you don't have the WorkshopDemoBundle class. You can
check what files you have in mapbender/src/Workshop/DemoBundle (you
should have WorkshopDemoBundle.php) and if the class is correctly
named (namespace Workshop\DemoBundle; and class WorkshopDemoBundle
Best regards, Andreas
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160613/cd4c5cc6/attachment.sig>
More information about the Mapbender_users
