[Mapbender-users] Error when trying to make a custom template
Uwe Seher uwe.seher at gmail.com
Tue Jun 14 05:53:24 PDT 2016
Hi!
Seem to take me a step further, thank you.
Ok, at the end the Workshop dir has been placed in the wrong directory.
As i placed it in <installdir>/src and not in <installdir>/mapbender/src it
worked perfect.
Thank you very much for your help!
Best regards, Uwe
2016-06-13 15:45 GMT+02:00 Andreas Schmitz <andreas.schmitz at wheregroup.com>:
> Uwe Seher wrote:
> Hi,
> > The full path is
> /srv/www/htdocs/intranet/mapbender3/mapbender/src/Workshop/DemoBundle/WorkshopDemoBundle.php
> > I checked owner and rights and everything seems to be like in the
> > Mapbender-Dir on the same level.
> > The classfile itself is unchanged direct from the download.
> perhaps the autoloader has not been dumped yet. Try installing
> composer as outlined in
> http://doc.mapbender3.org/en/book/installation/installation_git.html#composer
> Then try
> composer dump-autoload
> After that, the system should find the class.
> Best regards, Andreas
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160614/c4ea52cb/attachment.html>
More information about the Mapbender_users mailing list
