[Mapbender-users] Mapbender 2.7.4: Using password secured wfs services
Armin Retterath armin.retterath at lvermgeo.rlp.de
Wed Mar 2 04:29:20 PST 2016
hi lukas,
using secured (authenticated) wfs is only available in the trunk version
of mapbender2 as we use it in our federal geoportals (it will be part of
version 2.8).
to restrict public access to your wfs (geoserver), you have to restrict
access to localhost and register the geoserver wfs as a localhost url.
this should be sufficient.
you have to look in the geoserver documentation.
as an alternative, you can user the apache proxy module to proxy your
geoserver. this is quiet easy.
if you want, i send you a example configuration ;-)
armin
On 02.03.2016 13:00, lukas.bollack wrote:
> Hi mapbender mailing list!
> Since I'm using a geoserver wfs-t service I'm hosting myself that stores
> company data I would prefer having the service password protected. I already
> checked owsproxy for the corresponding wms service, so the service is hidden
> from the public. However if someone were to find out the wfs service
> location he or she could access the wfs service via QGIS or some other
> client and mess with the data. Is it possible for mapbender to access
> password protected wfs services? I don't see the option to specify a
> username and password for wfs services in the same fashion as for wms
> services.
> Can someone help me out?
> Regards
> Lukas
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapbender-2-7-4-Using-password-secured-wfs-services-tp5253786.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Von-Kuhl-Straße 49
56070 Koblenz
0261/492-466
http://www.geoportal.rlp.de
More information about the Mapbender_users mailing list
