[Mapbender-users] Antw: Re: Logo in Mapbender3
Gerhard Mocza
gerhard.mocza at boku.ac.at
Tue Mar 8 00:20:34 PST 2016
Thanks Astrid for your help !
It was the cache directory ...
kind regards
Gerhard
Gerhard Mocza
Institut f. Vermessung, Fernerkundung und Landinformation
Peter Jordan Str. 82
A-1190 Wien
Tel.: 47654/5117
email: gerhard.mocza at boku.ac.at
>>> Astrid Emde <astrid.emde at wheregroup.com> 07.03.2016 15:12 >>>
Hello Gerhard,
put the image at
mapbender3/mapbender/src/Mapbender/CoreBundle/Resources/public/image/
and set the permissions
please run afterwards
app/console assets:install web
Delete the content in the cache directory.
Try to access your Image in the browser (inspect with developer tools
F12)
Should be something like:
http://localhost/mapbender3/bundles/mapbendercore/image/logo_mb3.png
Best regards Astrid
Am 2016-03-07 15:07, schrieb Gerhard Mocza:
> Hi Astrid !
> Thanks for reply ! I've got all suggestions in mind and copied with
> and without sudo-rights assets to the web/bundle region.
> Also i've changed pyrameters.yml, which should include something
like
> global variables.
> Maybe i have to correct permissions anywhere (i've looked to
> owner-entry at folders to "www-data" too) ...
> Should i remove content in mapbender3/app/cache/dev-folder ?
> best regards
> Gerhard
> Gerhard Mocza
> A-1190 Wien
> Tel.: 47654/5117
>>>> Astrid Emde <astrid.emde at wheregroup.com> 07.03.2016 09:52 >>>
> Am 2016-03-04 14:08, schrieb Gerhard Mocza:
>> Hi all !
>> I' ve tried to change the logo as it is described in the manual.
>> Now it seems, no logo will be found.
>> Where is the twig-file, where i can change the logo ?
>> Thanks a lot
>> Gerhard
> Hello Gerhard,
> please keep in mind that your browser has only access to files in
the
> web section (ALIAS refers to web directory). So your logo has to be
> available there.
http://doc.mapbender3.org/en/book/directory_structure.html#web-bundles
> [1]
> These are the steps:
> 1. copy your logo to
> or
> to the image directory in your own bundle
> 2. run the command to copy the logo to the web/bundle region
> 3. Go to the parameters.yml file and change the path to the logo
> a) when it is in the mapbendercore region
> server_logo: bundles/mapbendercore/image/mylogo.png
> b) when you have your own bundle
> server_logo: bundles/mybundle/image/logo_mb3.png
> This should work.
> Best regards
> Astrid Emde
> GIS-Consultant
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 19
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com [2]
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284 [3]
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
> Links:
> [1]
> [2] http://twitter.com/WhereGroup_com
> [3] http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Astrid Emde
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Komplementärin:
vertreten durch:
pgp-public key:
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160308/a5a5913e/attachment.html>
More information about the Mapbender_users
