[Mapbender-users] connecting a database
Patrick Meis
Meis at stadt-muenster.de
Tue Mar 8 02:55:57 PST 2016
Hey Astrid,
i checked the log file and i get this error message whenenver i run an adress search:
[2016-03-08 10:32:00] request.CRITICAL: Uncaught PHP Exception Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException: "You have requested a non-existent service "doctrine.dbal.search_db_connection". Did you mean this: "doctrine.dbal.default_connection"?" at /var/www/mapbender3/app/bootstrap.php.cache line 2027 {"exception":"[object] (Symfony\\Component\\DependencyInjection\\Exception\\ServiceNotFoundException(code: 0): You have requested a non-existent service \"doctrine.dbal.search_db_connection\". Did you mean this: \"doctrine.dbal.default_connection\"? at /var/www/mapbender3/app/bootstrap.php.cache:2027)"} []
- I'm not quite sure what this means, whether my database cannot be connected, or if I did something wrong in the search router configuration...
This is what I wrote in my search routerconfiguration field:
class: Mapbender\CoreBundle\Component\SQLSearchEngine
class_options:
connection: search_db
relation: ADRESSE_GEOJSON_UTM
attributes:
- STR_NAME
- HSNR_GES
geometry_attribute: GEOM
form:
STR_NAME:
type: text
options:
required: true
label: Strasse
attr:
data-autocomplete: 'on'
HSNR_GES:
type: text
options:
required: false
label: Hausnummer
attr:
results:
view: table
count: true
headers:
STR_NAME: Straße
HSNR_GES: Hausnummer
callback:
event: click
options:
buffer: 1000
minScale: null
maxScale: null
STR_NAME and HSNR_GES and GEOM are attributes of the table ADRESSEN_GEOJSON_UTM
In the field GEOM I have geometry encoded in geojson specification.
Can you please try to help me again?
Thanks
Patrick
-----Ursprüngliche Nachricht-----
Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Astrid Emde
Gesendet: Montag, 7. März 2016 17:18
An: Mapbender User List
Betreff: Re: [Mapbender-users] connecting a database
Hi Patrick,
your configuration looks ok.
If the database is not needed in an application the connection is not
used.
http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/search_router.html
You can configure the searchrouter an will find out wether the
connection works.
You find an error in your log messages (F12) or in the log-file if the
connection fails.
Use app_dev.php and have a look in the dev-logfile.
http://localhost/mapbender3/app_dev.php
Best regards Astrid Emde
Am 2016-03-07 16:41, schrieb Patrick Meis:
> Hello,
> I'm just new to mapbender and i am currently trying to configure an
> address-search
> in mapbender3 via the "search router".
> So far I am only getting "No results found" whenever I enter a query.
> What I would like to do now is checking if my database connection to
> my "search_db"
> is working.
> From my config.yml:
> and from my parameters.yml:
> I am using mapbender v3.0.5.0. and I try to connect to an Oracle DB:
> Now is there an easy way to test the connection I defined?
> Regards
> Patrick
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users
