[Mapbender-users] Mapbender3: Change digitizing
Astrid Emde astrid.emde at wheregroup.com
Tue Mar 15 10:30:29 PDT 2016
Hello Siggi,
Am 2016-03-15 10:59, schrieb haukesigismund at web.de:
> Dear users,
> I successfully installed mapbender3 and also the digitize tool.
>  Good work, I like it very much :-)
Thanks for the compliment. I like Mpabender3 too, especially the
digitizer ;)
> I would like to do the following:
>  * A registered user can only see HIS OWN digitized points or
> polygons. For that after creating one point his login-name must be
> written in a column in the databasetable,
>  can anybody give me a hint where I can start that (Sofar I`m quite
> unsure whre I can begin in the code)?
>  It might be somewhere in
> /mapbender3/vendor/mapbender/digitizer/Mapbender/DigitizerBundle/Resources/public/mapbender.element.digitizer.js
>  But where can I have influence to the database-queries (Insert,
> Update, Delete, Select ?)
>  * Registered users can delete ONLY their OWN digitized points.
>  For the moment I would be glad to get the logged name. I thought
> somethink like "alert (app.user.username);" could give out the logged
> name, but it does not?
The behaviour you describe was discussed in the developer team too.
But it is not part of Mapbender3 yet. Digitizer should filter the
objects that are displayed and write the mapbender3 user to a column in
the data table.
If you are interested in the implementation and you have a budget you
can contact me so we can implement this behaviour.
Astrid
> Thank you very much, Siggi
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 19
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
  pgp-public key:
  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
