[Mapbender-users] Connection error with geometry server, internal error 500
zh.kerimkulov at gharysh.kz
Mon May 2 20:12:13 PDT 2016
Hi Astrid
Thanks for your support!!!
I checked all path in DB and YML files, looks the same.
I tried clear cache, but still got problems. In app_dev mode it works fine.
What I noticed in browser console that is error 500 on localhost/mapbender3/application/Portal/element/107/select?
Thank you
Zhandos
From: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] On Behalf Of Astrid Emde
Sent: Monday, May 2, 2016 12:28 PM
To: mapbender_users at lists.osgeo.org
Subject: Re: [Mapbender-users] Connection error with geometry server, internal error 500
Hi Zhandos,
please check the real name of your Database in PostgreSQL. Is it named seach_db as you wrote in parameter.yml (database2_name: search_db)?
Are you allowed to access the database?
Clear the cache
Call Mapbender with app_dev.php to get the errors. Something like http://localhost/mapbender3/app_dev.php
The rest looks fine.
Best regards
Astrid
Am 30.04.2016 09:09, schrieb zh.kerimkulov at gharysh.kz<mailto:zh.kerimkulov at gharysh.kz>:
Hello Mapbender Users!!!
I tried to use Digitizer element, but faced connection error with geometry server.
Step by step:
1/ I changed config.yml file:
doctrine:
dbal:
default_connection: default
connections:
default:
driver: %database_driver%
host: %database_host%
port: %database_port%
dbname: %database_name%
path: %database_path%
user: %database_user%
password: %database_password%
charset: UTF8
logging: %kernel.debug%
profiling: %kernel.debug%
search_db:
driver: %database2_driver%
host: %database2_host%
port: %database2_port%
dbname: %database2_name%
path: %database2_path%
user: %database2_user%
password: %database2_password%
charset: UTF8
2/ and parameters.yml file.
parameters:
# database-connection "default"
database_driver: pdo_pgsql
database_host: localhost
database_port: 5432
database_name: mapbender3
database_path: ~
database_user: postgres
database_password: postgres
# database-connection "search_db"
database2_driver: pdo_pgsql
database2_host: localhost
database2_port: 5432
database2_path: ~
database2_user: postgres
database2_password: postgres
3/ then I tried to create DB by console utility like this: app/console doctrine:database:create
But this utility create only default DB, search_db did not created by script. I create it manually and added extension Postgis. After that I added tables with SQL query for tables table public.poi, public.polygons, public.lines, then I added Digitizer element to the side panel of application and put YAML-Definition to the textarea schemes but it did not solve the problem, I still have "Connection error with geometry server, internal error 500".
Thank you,
Zhandos
Mapbender_users mailing list
Mapbender_users at lists.osgeo.org<mailto:Mapbender_users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu<http://www.foss-academy.eu>
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com<mailto:astrid.emde at wheregroup.com>
www.wheregroup.com<http://www.wheregroup.com>
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20160503/0168ae3d/attachment-0001.html>
More information about the Mapbender_users
