[Mapbender-users] composer update fails due to toooni/fpdf package
Axel Schaefer axel.schaefer at wheregroup.com
Wed May 25 04:19:00 PDT 2016
Dear Mapbender developers (cc/x-post: mapbender_users)
If you want to do a composer update you'll notice an error concerning
the package:  toooni/fpdf. The package cannot be found and used.
The package is referenced in composer.json:
         "toooni/fpdf": "dev-master",
We are looking for a solution how to prevent that issue and will provide
a hotfix for that.
Project-specific builds, that some users use are not affected by this.
Although if you do a composer update or composer install for yourself
you'll run into this error.
Regards,
Axel
Axel Schaefer
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 31
Fax: +49 (0)228 / 90 90 38 - 11
www.meldemax.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
