[Mapbender-users] problem with digitizer
    eSlider
    andriy.oblivantsev at wheregroup.com
    Wed May 25 06:00:48 PDT 2016
Hello Sebastian,
there is an apache error log file you can get error details:
tail -f /var/log/apache2/error.log
By the way, here is YAML based example dev. application configuration:
https://github.com/mapbender/mapbender-starter/blob/feature/digitizer/application/app/config/applications/test-digitizer.yml
Regards,
Andriy
https://github.com/eSlider
View this message in context: http://osgeo-org.1560.x6.nabble.com/problem-with-digitizer-tp5266685p5268157.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users
