[Mapbender-users] php issues trying to install mapbender3 on Debian/testing with php7
Astrid Emde
astrid.emde at wheregroup.com
Wed Nov 2 04:23:20 PDT 2016
Hello Moritz,
thanks for your mail with the solution of your problem. Great Mapbender3
works now!
I added the information to the documentation.
http://doc.mapbender3.org/en/book/installation/installation_ubuntu.html
Best regards Astrid
Am 13.10.2016 11:33, schrieb Moritz Lennert:
> Sorry, my bad: I forgot to run "sudo a2enmod php7.0".
> (maybe a note about this in the doc might be good)
> Now http://localhost/mapbender3 gives me Mapbender ! ;-)
> Sorry for the noise,
> Moritz
> On 12/10/16 15:51, Moritz Lennert wrote:
>> Some more info:
>> Using Chromium (instead of Firefox), I get the entire php code displayed
>> in the browser, be it for
>> - http://localhost/mapbender3 (i.e. web/app.php) or
>> - http://localhost/mapbender3/config.php (i.e. web/config.php)
>> And here are all the php related packages that are installed on my
>> machine:
>> dpkg -l "*php*" | grep ii | awk '{print $1, $2, $3}'
>> ii libapache2-mod-php 1:7.0+45
>> ii libapache2-mod-php7.0 7.0.11-1
>> ii php 1:7.0+45
>> ii php-apcu 5.1.5+4.0.11-1
>> ii php-apcu-bc 1.0.3-2
>> ii php-bz2 1:7.0+45
>> ii php-cli 1:7.0+45
>> ii php-common 1:44
>> ii php-curl 1:7.0+45
>> ii php-gd 1:7.0+45
>> ii php-intl 1:7.0+45
>> ii php-mbstring 1:7.0+45
>> ii php-mdb2 2.5.0b5-2
>> ii php-mdb2-driver-pgsql 1.5.0b4-2
>> ii php-pear 1:1.10.1+submodules+notgz-8
>> ii php-pgsql 1:7.0+45
>> ii php-sqlite3 1:7.0+45
>> ii php-xml 1:7.0+45
>> ii php-zip 1:7.0+45
>> ii php7.0 7.0.11-1
>> ii php7.0-bz2 7.0.11-1
>> ii php7.0-cli 7.0.11-1
>> ii php7.0-common 7.0.11-1
>> ii php7.0-curl 7.0.11-1
>> ii php7.0-gd 7.0.11-1
>> ii php7.0-intl 7.0.11-1
>> ii php7.0-json 7.0.11-1
>> ii php7.0-mbstring 7.0.11-1
>> ii php7.0-opcache 7.0.11-1
>> ii php7.0-pgsql 7.0.11-1
>> ii php7.0-readline 7.0.11-1
>> ii php7.0-sqlite3 7.0.11-1
>> ii php7.0-xml 7.0.11-1
>> ii php7.0-zip 7.0.11-1
>> Moritz
>> On 12/10/16 15:39, Moritz Lennert wrote:
>>> Hi Frederik,
>>> Thank you for the quick response !
>>> On 11/10/16 17:58, Frederik Haefker (WhereGroup) wrote:
>>>> Hi Moritz,
>>>> did you rename your "parameter.yml.dist" in following folder
>>>> "app/config/" by removing the ".dist"?
>>> I've just tried this, but no changes.
>>> This step is only described in [1] which is announced as "Installation
>>> in the Symfony built-in webserver". I didn't think I had to go through
>>> there.
>>> Looking at this I tried to run and reach the Symfony server with:
>>> sudo app/console server:run
>>> which gives me
>>> "Server running on http://localhost:8000"
>>> But when I point my browser to that address, I get:
>>> "Firefox can't establish a connection to the server at localhost:8000."
>>> I've tried stopping the apache2 service in order to avoid any possible
>>> conflicts, but to no avail.
>>> I've also gone a bit further in the Ubuntu/Debian installation guide
>>> [2]
>>> and changed the ownership of all files to www-data with:
>>> sudo chmod -R ugo+r /var/www/mapbender3
>>> sudo chown -R www-data:www-data /var/www/mapbender3
>>> sudo chmod -R ug+w /var/www/mapbender3/web/uploads
>>> No changes either. I still get the same unreadable web page...
>>> Moritz
>>> [1]
>>> http://doc.mapbender3.org/en/book/installation/installation_symfony.html
>>> [2]
>>>> Best Regards
>>>> Frederik
>>>> Am 11.10.2016 um 17:34 schrieb Moritz Lennert:
>>>>> Hello there,
>>>>> I'm new to Mapbender and am having quite some issues just trying to
>>>>> install it. Any help would be appreciated.
>>>>> Below a summary of my situation and of what I've done.
>>>>> Thanks !
>>>>> Moritz
>>>>> OS: Debian testing
>>>>> Apache Version: 2.4.23
>>>>> PHP Debian version: 1:7.0+45
>>>>> I "apt-get removed" any remaining installed php5 packages (php5 is no
>>>>> longer supported in Debian testing)
>>>>> sudo apt-get install apache2 libapache2-mod-php php php-pgsql php-gd
>>>>> php-curl php-cli php-xml php-sqlite3 sqlite3 php-apcu php-intl
>>>>> openssl
>>>>> php-zip php-mbstring php-bz2
>>>>> sudo a2enmod rewrite
>>>>> cd /var/www
>>>>> sudo tar xvzf ~/SRC/mapbender3-3.0.5.3.tar.gz
>>>>> sudo mv mapbender3-3.0.5.3/ mapbender3
>>>>> sudo vi mapbender3.conf
>>>>> Alias /mapbender3 /var/www/mapbender3/web/
>>>>> <Directory /var/www/mapbender3/web/>
>>>>> Options MultiViews FollowSymLinks
>>>>> DirectoryIndex app.php
>>>>> Require all granted
>>>>> RewriteEngine On
>>>>> RewriteBase /mapbender3/
>>>>> RewriteCond %{REQUEST_FILENAME} !-f
>>>>> RewriteRule ^(.*)$ app.php [QSA,L]
>>>>> </Directory>
>>>>> sudo a2ensite mapbender3.conf
>>>>> sudo service apache2 reload
>>>>> When I now point my browser to
>>>>> I get a page with this:
>>>>> register(true); */ require_once __DIR__.'/../app/AppKernel.php';
>>>>> //require_once __DIR__.'/../app/AppCache.php'; $kernel = new
>>>>> AppKernel('prod', false); $kernel->loadClassCache(); //$kernel = new
>>>>> AppCache($kernel); $request = Request::createFromGlobals(); $response
>>>>> = $kernel->handle($request); $response->send();
>>>>> $kernel->terminate($request, $response);
>>>>> When I point it to
>>>>> I get to the config page, but with apparently a series of PHP issues
>>>>> (see attached screenshot)
>>>>> After having seen an error about date.timezone on
>>>>> http://doc.mapbender3.org/en/book/installation/installation_ubuntu.html:
>>>>> sudo vi /etc/php/7.0/cli/php.ini
>>>>> sudo vi /etc/php/7.0/apache2/php.ini
>>>>> date.timezone = Europe/Brussels
>>>>> sudo service apache2 restart
>>>>> => same result
>>>>> _______________________________________________
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>> Ps.: bitte beachten Sie die Möglichkeit den Schriftverkehr mit meinem
>>>> public-PGP-key zu schützen:
>>>> http://pool.sks-keyservers.net/pks/lookup?op=vindex&search=frederik+haefker
>>>> INTERGEO 2016
>>>> 11.- 13. Oktober 2016 in Hamburg
>>>> Treffen Sie die WhereGroup in Halle A4, Stand B4.028
>>>> www.intergeo.de
>>>> Frederik Haefker
>>>> WhereGroup GmbH & Co. KG
>>>> Eifelstraße 7
>>>> 53119 Bonn
>>>> Germany
>>>> Fon: +49 (0)228 / 90 90 38 - 0
>>>> Fax: +49 (0)228 / 90 90 38 - 11
>>>> PGP Key:
>>>> frederik.haefker at wheregroup.com
>>>> www.wheregroup.com
>>>> Amtsgericht Bonn, HRA 6788
>>>> Komplementärin:
>>>> WhereGroup Verwaltungs GmbH
>>>> vertreten durch:
>>>> Olaf Knopp, Peter Stamm
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Where2B Konferenz 2016
15. Dezember 2016 in Bonn
www.where2b-conference.com
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Komplementärin:
vertreten durch:
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161102/3af615c2/attachment.html>
More information about the Mapbender_users
