[Mapbender-users] I can not adjust SearchRouter. Please help
Charlotte Toma
charlotte.toma at wheregroup.com
Tue Nov 15 06:50:50 PST 2016
Hello there,
1/1ParameterNotFoundException: You have requested a non-existent parameter
"fallback_locale".
Is the following parameter in your parameters.yml set correct?
[db connections... please don't show your passwords....]
# locale en, de, it, es, ru, nl, pt are available
* fallback_locale: en*
locale: en
secret: ThisTokenIsNotSoSecretChangeIt
Am 15.11.2016 um 14:59 schrieb Den:
> Having worked with settings and having transferred all folders of the server
> to the root directory C: received the following -
> http://localhost/mapbender3/config.php
> Welcome!
> Welcome to your new Symfony project.
> This script will guide you through the basic configuration of your project.
> You can also do the same by editing the ‘app/config/parameters.yml’ file
> directly.
> Your configuration looks good to run Symfony.
> Configure your Symfony Application online
> Bypass configuration and go to the Welcome page
> http://localhost/mapbender3/app_dev.php
> Whoops, looks like something went wrong.
> "fallback_locale".
> in
> C:\mapbender3\vendor\symfony\symfony\src\Symfony\Component\DependencyInjection\ParameterBag\ParameterBag.php
> line 96
> at ParameterBag->get('fallback_locale') in
> line 216
> at ParameterBag->resolveString('%fallback_locale%', array()) in
> line 187
> at ParameterBag->resolveValue('%fallback_locale%', array()) in
> line 177
> at ParameterBag->resolveValue(array('fallback' => '%fallback_locale%'),
> array()) in
> line 177
> at ParameterBag->resolveValue(array('translator' => array('fallback' =>
> '%fallback_locale%'), 'secret' => '%secret%', 'router' => array('resource'
> => '%kernel.root_dir%/config/routing.yml', 'strict_requirements' =>
> '%kernel.debug%'), 'form' => true, 'csrf_protection' => true, 'validation'
> => array('enable_annotations' => true), 'templating' => array('engines' =>
> array('twig')), 'default_locale' => '%locale%', 'session' =>
> array('cookie_httponly' => true, 'cookie_secure' => '%cookie_secure%',
> 'cookie_lifetime' => '%cookie_lifetime%')), array()) in
> line 177
> at ParameterBag->resolveValue(array(array('translator' => array('fallback'
> => '%fallback_locale%'), 'secret' => '%secret%', 'router' =>
> array('resource' => '%kernel.root_dir%/config/routing.yml',
> 'strict_requirements' => '%kernel.debug%'), 'form' => true,
> 'csrf_protection' => true, 'validation' => array('enable_annotations' =>
> true), 'templating' => array('engines' => array('twig')), 'default_locale'
> => '%locale%', 'session' => array('cookie_httponly' => true, 'cookie_secure'
> => '%cookie_secure%', 'cookie_lifetime' => '%cookie_lifetime%')),
> array('router' => array('resource' =>
> '%kernel.root_dir%/config/routing_dev.yml'), 'profiler' =>
> array('only_exceptions' => false)))) in
> C:\mapbender3\vendor\symfony\symfony\src\Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass.php
> line 44
> at MergeExtensionConfigurationPass->process(object(ContainerBuilder)) in
> C:\mapbender3\vendor\symfony\symfony\src\Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass.php
> line 39
> C:\mapbender3\vendor\symfony\symfony\src\Symfony\Component\DependencyInjection\Compiler\Compiler.php
> line 108
> at Compiler->compile(object(ContainerBuilder)) in
> C:\mapbender3\vendor\symfony\symfony\src\Symfony\Component\DependencyInjection\ContainerBuilder.php
> line 572
> at ContainerBuilder->compile() in C:\mapbender3\app\bootstrap.php.cache line
> 2521
> at Kernel->initializeContainer() in C:\mapbender3\app\bootstrap.php.cache
> line 2300
> at Kernel->boot() in C:\mapbender3\app\bootstrap.php.cache line 2331
> at Kernel->handle(object(Request)) in C:\mapbender3\web\app_dev.php line 28
> http://localhost/mapbender3/app.php
> Normally loaded Mapbender page. Authorization works.
> config.yml contents
> doctrine:
> dbal:
> default_connection: default
> connections:
> default:
> driver: %database_driver%
> host: %database_host%
> port: %database_port%
> dbname: %database_name%
> path: %database_path%
> user: %database_user%
> password: %database_password%
> charset: UTF8
> logging: %kernel.debug%
> profiling: %kernel.debug%
> search_db:
> driver: %database2_driver%
> host: %database2_host%
> port: %database2_port%
> dbname: %database2_name%
> path: %database2_path%
> user: %database2_user%
> password: %database2_password%
> charset: UTF8
> orm:
> auto_generate_proxy_classes: %kernel.debug%
> auto_mapping: true
> and parameters.yml
> parameters:
> default:
> database_driver: pdo_pgsql
> database_host: localhost
> database_port: 5432
> database_name: mapbender3
> database_path: ~
> database_user: postgres
> database_password: n36rp21
> search_db:
> database2_driver: pdo_pgsql
> database2_host: localhost
> database2_port: 5432
> database2_name: search_db
> database2_path: ~
> database2_user: postgres
> database2_password: n36rp21
> configuration
> Oracle Virtualbox, Win7 32bit Pro, Apache/2.4.23 (Win32) PHP/5.6.26.
> PHPinfo
> pdo_pgsql
> PDO Driver for PostgreSQL enabled
> PostgreSQL(libpq) Version 9.4.5
> Module version 1.0.2
> Revision $Id: 0e858dd2051ca8c2fd3c781909a0670ab5fecd36 $
> pgsql
> PostgreSQL Support enabled
> PostgreSQL(libpq) 9.4.5 (win32)
> Multibyte character support enabled
> SSL support enabled
> Active Persistent Links 0
> Active Links 0
> Directive Local Value Master Value
> pgsql.allow_persistent On On
> pgsql.auto_reset_persistent Off Off
> pgsql.ignore_notice Off Off
> pgsql.log_notice Off Off
> pgsql.max_links Unlimited Unlimited
> pgsql.max_persistent Unlimited Unlimited
> I have no confidence that will earn search if there is an error in the
> app_dev mode.
> You couldn't clear a situation or prompt at least where to look for an
> error?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/I-can-not-adjust-SearchRouter-Please-help-tp5295321p5295856.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Charlotte Toma
GIS-Consultant
Where2B Konferenz 2016
15. Dezember 2016 in Bonn
www.where2b-conference.com
Charlotte Toma
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 24
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161115/a7a9178e/attachment.html>
More information about the Mapbender_users
