[Mapbender-users] WmsInstance#source are inconsistent with each other, WmsSource must be private or protected
Mike1973 mlendowsky at gmail.com
Wed Sep 7 03:45:00 PDT 2016
Hi Everyone,
I'm getting the following error message
The mappings Mapbender\WmsBundle\Entity\WmsSource#instances and
Mapbender\WmsBundle\Entity\WmsInstance#source are inconsistent with each
other.
Field 'getCapabilities' in class 'Mapbender\WmsBundle\Entity\WmsSource' must
be private or protected. Public fields may break lazy-loading.
Field 'getMap' in class 'Mapbender\WmsBundle\Entity\WmsSource' must be
My WMS getcapabilities loads, but map layers are not visible.
Also, is there a way for me to disable the owsproxy3 bundle.
Have a feeling that this might be causing my WMS not to resolve correctly.
Thank you.
View this message in context: http://osgeo-org.1560.x6.nabble.com/WmsInstance-source-are-inconsistent-with-each-other-WmsSource-must-be-private-or-protected-tp5284475.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
