[Mapbender-users] 'Feature Info' works for certain WMS only in the "WMS loader", but not when added from 'source'
Henning Lorenz henning.lorenz at geo.uu.se
Thu Sep 15 04:55:44 PDT 2016
Thank you for the quick and effective help, Astrid.
Yes, it was the “Allowed MIME types for a GetFeatureInfo request” in Geoserver. Apparently, the ‘WMS loader’ is more flexible than ’sources’ with regard to GetFeatureInfo formats.
Just in case somebody else with a similar problem comes across this post: It is necessary to actively refresh/update the source in Mapbender after the WMS update in Geoserver.
Henning
> On 15 Sep 2016, at 12:51, Astrid Emde <astrid.emde at wheregroup.com> wrote:
> Hello Henning,
> I have an addition about featureInfo and "only valid".
> You wrote: ‘Feature Info’ returns a ‘WMS server: no result’ for my layer
> The featureInfo Element has an option "only valid"
> If you activate "onbly valid" you have to make sure, that the answer represents a valid HTML.
> If you have defined text/plan as output-format, the switch only valid must not be activated because text/plain doesn’t return valid HTML.
> "Only valis" is a nice feature, as it will not open the dialog when an empty page / no result comes back.
> Read more:
> http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/feature_info.html#configuration
> Astrid
> Am 2016-09-15 12:44, schrieb Astrid Emde:
>> Hello Henning,
>> looks like it has to do with the featureInfo format.
>> You would like to get a featureInfo answer in text/html.
>> Please go to your application-Layerset->GeoServer WMS and check the
>> WMS infoformat. It should be set to text/html. Please save afterwards.
>> GeoServer offers many infoformats in the getCapabilities Document.
>> Mapbender chooses the first which is not always text/html.
>> Astrid
>> Am 2016-09-15 12:16, schrieb Henning Lorenz:
>>> Mapbender v.3.0.5.3; Geoserver 2.9.1
>>> Hello,
>>> - I have a WMS V.1.1.1 from Geoserver that I want to add to Mapbender 3
>>> - I can add the WMS without problems as a source
>>> - When I add layers from the WMS to a map, e.g. to one of the
>>> templates that come with Mapbender3, they show up correctly but:
>>>             * ‘Feature Info’ returns a ‘WMS server: no result’ for my layer
>>>             * ‘Feature Info’ works correctly on other WMS layers,
>>> like the Mapbender3 user map
>>> - When I add the very same WMS through the WMS loader, then ‘Feature
>>> Info’ works just fine.
>>> ———— this does not depend on the CRS, i.e. whether original or projected.
>>> - When I add this WMS to the same map twice, once as map layers from
>>> ‘sources’ and then again through ‘WMS loader’ and query the same
>>> feature  of the same layer in both WMSs with on click, i.e. at the
>>> same time, then the query on the ‘WMS loader’ layer returns a correct
>>> ‘Feature Info’ while the layer from ’sources’ returns ‘WMS server: no
>>> result’.
>>> Where is the difference between the ‘WMS loader’ and the ‘sources’?
>>> I’m grateful for any hint that helps me with troubleshooting.
>>> Thank you!
>>> Henning
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Mit freundlichen Grüßen
>> Astrid Emde
>> GIS-Consultant
>> INTERGEO 2016
>> 11.- 13. Oktober 2016 in Hamburg
>> Treffen Sie die WhereGroup in Halle A4, Stand B4.028
>> www.intergeo.de
>> Astrid Emde
>> WhereGroup GmbH & Co.KG
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 22
>> Fax: +49(0)228 90 90 38 - 11
>> www.wheregroup.com
>> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> pgp-public key:
>> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>> Signed and/or encrypted mail is highly appreciated
> Astrid Emde
> GIS-Consultant
> INTERGEO 2016
> www.intergeo.de
> Astrid Emde
> Eifelstraße 7
> 53119 Bonn
> Germany
> www.wheregroup.com
> Komplementärin:
> vertreten durch:
> pgp-public key:
More information about the Mapbender_users mailing list
