[Mapbender-users] WG: Mapbender3 - Konfiguration Search Router
Geodaten WiplferPlan
geodaten at wipflerplan.de
Mon Apr 3 04:26:43 PDT 2017
Hallo zusammen,
ich habe in unserem Mapbender Projekt versucht Search Router zu integrieren,
bekomme aber immer die Meldung No results found.
Die config.yml sieht so aus:
"doctrine:
dbal:
default_connections: default
connections:
default:
driver:
%database_driver%
host:
%database_host%
port:
%database_port%
dbname:
%database_name%
path:
%database_path%
user:
%database_user%
password:
%database_password%
charset: UTF8
logging: %kernel.debug%
profiling:
%kernel.debug%
postgres:
driver:
%database2_driver%
host:
%database2_host%
port:
%database2_port%
dbname:
%database2_name%
path:
%database2_path%
user:
%database2_user%
password:
%database2_password%
charset: UTF8
profiling:
%kernel.debug%
orm:
auto_generate_proxy_classes: %kernel.debug%
auto_mapping: true"
Die parameters.yml so:
"parameters:
database_driver: pdo_pgsql
database_host: *****
database_port: 5432
database_name: mapbender3
database_path: ~
database_user: postgres
database_password: *****
database2_driver: pdo_pgsql
database2_host: *****
database2_port: 5432
database2_name: postgres
database2_path: ~
database2_user: postgres
database2_password: *****
mailer_transport: smtp
mailer_host: localhost
mailer_user: ~
mailer_password: ~
# locale en, de, it, es, ru, nl, pt are available
fallback_locale: en
locale: en
secret: ThisTokenIsNotSoSecretChangeIt
fom:
server_name: Mapbender3
server_version: 3.0.5.3
server_logo: bundles/mapbendercore/image/logo_mb3.png
# framework :
<http://symfony.com/doc/2.1/reference/configuration/framework.html#cookie-li
fetime>
http://symfony.com/doc/2.1/reference/configuration/framework.html#cookie-lif
etime
cookie_secure: false
cookie_lifetime: 3600
# OWSProxy Configuration
ows_proxy3_logging: false
ows_proxy3_obfuscate_client_ip: true
ows_proxy3_host: ~
ows_proxy3_port: ~
ows_proxy3_connecttimeout: 60
ows_proxy3_timeout: 90
ows_proxy3_user: ~
ows_proxy3_password: ~
ows_proxy3_noproxy: ~
und die Konfiguration der Suche in Mapbender wie folgt:
"class: Mapbender\CoreBundle\Component\SQLSearchEngine
class_options:
connection: postgres
relation: public.Kundenstamm
attributes:
- id
- bez_gem
geometry_attribute: geom
form:
Gemeinde:
type: text
options:
required: true
compare: exact
results:
view: table
count: true
headers:
bez_gem: Name
callback:
event: click
options:
buffer: 10
minScale: null
maxScale: null"
In der prod.log steht folgende Fehlermeldung:
[2017-04-03 10:38:12] request.CRITICAL: Uncaught PHP Exception
Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException:
"You have requested a non-existent service
"doctrine.dbal.postgres_connection". Did you mean this:
"doctrine.dbal.default_connection"?" at
/var/www/mapbender3/app/bootstrap.php.cache line 2048 {"exception":"[object]
(Symfony\\Component\\DependencyInjection\\Exception\\ServiceNotFoundExceptio
n(code:
0): You have requested a non-existent service
\"doctrine.dbal.postgres_connection\". Did you mean this:
\"doctrine.dbal.default_connection\"? at
/var/www/mapbender3/app/bootstrap.php.cache:2048)"} []
Ich habe ähnliche Probleme
(http://osgeo-org.1560.x6.nabble.com/connecting-a-database-td5254910.html,
http://osgeo-org.1560.x6.nabble.com/Mapbender3-Searchrouter-additional-datab
ase-connection-td5303306.html
) bereits im Forum gefunden, die dort vorgeschlagenen Lösungen haben aber
nichts geändert soweit ich sie umsetzen konnte.
Über Lösungsansätze würde ich mich sehr freuen.
Freundliche Grüße
Markus Lütke Brintrup
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170403/6d05c57c/attachment-0001.html>
More information about the Mapbender_users
