[Mapbender-users] Overview element in print template has no content
Uwe Seher uwe.seher at gmail.com
Wed Feb 8 01:38:33 PST 2017
Hello!
No, i haven't  found a solution yet.
1.) I modified the original Template A3 landscape with overview.
2.) I check this
3.) I check the logs. Or where else can i get the request from the template?
4.) Yes.
Thank you!
Best regards
Uwe
2017-02-07 10:51 GMT+01:00 Astrid Emde <astrid.emde at wheregroup.com>:
> Hello Uwe,
> please check the following:
> 1. use an existing template from mapbender with an overview map:
> /Resources/MapbenderPrintBundle/templates/a4portrait.odg
> 2. could it be a scale probem? Does your WMS gives back an image at every
> scale
> 3. Check the getMap-Request - does it give back a valid png?
> 4. is the region in your template named "overview" (looks like, because
> the red rectangle is drawn)
> Hope this will help.
> If you have already a solution, please let us know.
> Astrid
> Am 2017-02-02 11:08, schrieb Uwe Seher:
>> Hello group!
>> I am trying to use the overview  element in a print template, but it
>> does not show any content.Only the red rectangle for the print frame
>> is shown. Everything else is working as expected. Can someone give me
>> a hint what i am doing wrong here?
>> Thank you
>> Uwe Seher
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> FOSS Academy Winterschule 2017
> 20.-24.03.2017 in Bonn
> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
>  Astrid Emde
>  WhereGroup GmbH & Co.KG
>  Eifelstraße 7
>  53119 Bonn
>  Germany
>  Fon: +49(0)228 90 90 38 - 22
>  Fax: +49(0)228 90 90 38 - 11
>  www.wheregroup.com
>  Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
>  pgp-public key:
>  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
>  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>  Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170208/380c5eec/attachment.html>
More information about the Mapbender_users mailing list
