[Mapbender-users] Mapbender3: Handling dynamic_image/dynamic_text in print-templates
Astrid Emde astrid.emde at wheregroup.com
Tue Jan 10 08:10:04 PST 2017
Hallo,
it looks like you followed the instruction at.
http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/printclient.html#configuration-of-the-element
Did you check the access rights for the new files on linux?
Please send your odg file to me and I will have a look.
Astrid
Am 2017-01-10 14:47, schrieb Uwe Seher:
> Hello Mapbenderlist!
> I like to create some print templates for some projectmaps which
> should look the same with different logos and titles.
> I created the odg-file and the pdf and it works fine, but the elements
> dynamic_image and dynamic_text are not filled in the resulting map.
> What i have done:
> - created elements in the template (copied from Northarrow and title
> and adjusted the name to dynamic_image and dynamic_text). They are on
> the layer with the other dynamic elements.
> - put the file in app/Resources/MapbenderPrintBundle/images
> - adusted the owner/rights according the other files
> Does it matter if the groupname has an uppercase Letter at start (the
> file is named the same)?
> Maybe someone can give me a brief introducion what i have to do to
> make the template work.
> Thank you in advance
> Uwe Seher
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Winterschule 2017
20.-24.03.2017 in Bonn
Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
  pgp-public key:
  http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated
More information about the Mapbender_users mailing list
