[Mapbender-users] Problem using the Search Router (can't find table)
Patrice
abrabacabra at openmailbox.org
Sat Jul 1 07:15:39 PDT 2017
I am trying to use the Search Router bundle in an application, but it fails.
At first, it could not find the database, so I have setup the database
in config.yml and parameters.yml.
Now, it can't find the table to search in.
Here is the error in prod.log:
[2017-07-01 14:04:54] request.CRITICAL: Uncaught PHP Exception
Doctrine\DBAL\DBALException: "An exception occurred while executing
'SELECT t.objectid, t.code_proje, ST_AsGeoJSON(geom) as geom FROM
data.aires_prot_priv t WHERE LOWER(t.code_proje) LIKE LOWER(?)' with
params ["%tabi%"]: SQLSTATE[HY000]: General error: 1 no such table:
data.aires_prot_priv" at
C:\ms4w\apps\mapbender3-3.0.5.3\vendor\doctrine\dbal\lib\Doctrine\DBAL\DBALException.php
line 91 {"exception":"[object] (Doctrine\\DBAL\\DBALException(code: 0):
An exception occurred while executing 'SELECT t.objectid, t.code_proje,
ST_AsGeoJSON(geom) as geom FROM data.aires_prot_priv t WHERE
LOWER(t.code_proje) LIKE LOWER(?)' with params
[\"%tabi%\"]:\n\nSQLSTATE[HY000]: General error: 1 no such table:
data.aires_prot_priv at
C:\\ms4w\\apps\\mapbender3-3.0.5.3\\vendor\\doctrine\\dbal\\lib\\Doctrine\\DBAL\\DBALException.php:91,
PDOException(code: HY000): SQLSTATE[HY000]: General error: 1 no such
table: data.aires_prot_priv at
C:\\ms4w\\apps\\mapbender3-3.0.5.3\\vendor\\doctrine\\dbal\\lib\\Doctrine\\DBAL\\Connection.php:691)"}
The table "aires_prot_priv" does exist in the "data" schema and I have
the necessary right to read from it (made the test with pgAdmin using
the same credentials as specified in parameters.yml).
However, as my database and schema are already filled with the data I
want to use, I didn't create the database and schema using
"|doctrine:database:create|". Is this mandatory in order to use the
search router?
What am I missing?
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170701/ae1a0b4d/attachment.html>
More information about the Mapbender_users
