[Mapbender-users] Mapbender 3.0.6.0: Digitizer-Toolsets
Uwe Seher
uwe.seher at gmail.com
Mon Jul 31 02:45:39 PDT 2017
Hello!
I have a problem using the toolsets in the digitizer element. I am using
the toolsets drawPoint, moveFeature, selectFeature, removeSelected in my
map. The only one, that works correct is the drawPoint-tool, it creates a
new point. When i use the other tools, i can move the element on the map
or delete it, but nothing is written in the database. If i move a point, i
can edit it with the contextmenu and save it. In this way the changes are
written into the database. If i select a feature for deletion i can delete
it from the screen but it is not deleted in the database and appears again
after refreshing the map. Deleting with the contextmenue is working fine.
In the documentation the tools selectFeature and removeSelected are marked
as experimental, but the delete workflow is mentioned as working. also the
moveFeature-tool is not marked as experimental, so i think i should work.
When using the functions in the table everything works as expected. Did i
miss something in the configuration?
Thank you in advance
Uwe Seher
PS:
This is the relevant part of the configuration:
allowEditData: true
allowDelete: true
allowDigitize: true
useContextMenu: true
toolset:
type: drawPoint
type: moveFeature
type: selectFeature
type: removeSelected
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170731/986053ff/attachment.html>
More information about the Mapbender_users
