[Mapbender-users] Install Mapbender3 in macOS with XAMPP
Axel Schaefer
axel.schaefer at wheregroup.com
Wed May 3 04:35:24 PDT 2017
Hi.
Take a look into the Apache Logs. Any errors?
Check, that you have installed Mapbender properly. Does it react to the
URL? Does it log someting in app/logs/prod.log?
Which version of PHP and which download of MB3? The 3.0.5 branch doesn't
support PHP7 yet so if your Sierra is shipped with PHP 7 it will not run.
One note to the databases: You have some possibilities for a database
for Mapbender: PostgreSQL, MySQL or SQLite (and Oracle, if you want to).
Only the MB3-Configuration is stored there, no geodata. For geodata, you
need a spatial enabled database.
If you are more like a developer you can also take a look into the
Contributing.md to cross-check your installation.
https://github.com/mapbender/mapbender-starter/blob/release/3.0.6/CONTRIBUTING.md
Best regards,
Axel
Am 25.04.2017 um 16:11 schrieb ledungtdc:
> I installed XAMPP with:
> - Apache/2.4.23 (Unix)
> - PHP/5.6.24
> I also installed PostgreSQL 9.5
> All work well and I can run Wordpress, Joomla or my own PHP code locally in
> my MacBook with macOS Sierra 10.12.4
> I tried to install MapBender3 in the way guides for Ubuntu and Debian but
> never success. The browser responds nothing (Server not found).
> Anyone can help me in this case
> Thanks
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Install-Mapbender3-in-macOS-with-XAMPP-tp5318350.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
