[Mapbender-users] Custom element that displays the result of a SQL query
Abrabacabra
abrabacabra at openmailbox.org
Wed May 24 19:33:43 PDT 2017
I simply need to display, maybe in the toolbar or something, a single
dynamic numeric value based on the result of a query made to the
PostgreSQL database we use for the daily operations of the organization.
It would be preceded by a string like: "The value is:" ([value])
Is there a currently available element/bundle that allows us to do that?
On 2017-05-24 4:30 AM, Uwe Seher wrote:
> Hello!
> You should provide a little more information what you want to do.
> You can use different approches to solve this. In mapbender i think,
> you can use something like the search or the digitizer element. These
> can use a sql-query direct from mapbender. You only have to configure
> the database connection. But when you use a wms layer in the behind, a
> getfeatureinfo is maybe the better approach.
> best regards
> Uwe Seher
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170524/e8401222/attachment.html>
More information about the Mapbender_users
