[Mapbender-users] Search Router Problem
Astrid Emde
astrid.emde at wheregroup.com
Wed Nov 29 22:22:55 PST 2017
Hello,
the SearchRouter does not transform the results. So you have to make
sure that the results are in the same projection as the map.
Astrid
Am 2017-11-29 23:31, schrieb fcortesz:
> I have the following problem when trying to use the Search Router, I do
> the
> search correctly, when I click on it it does not move me to it, someone
> could advise me about it.
> Thank you
> class: Mapbender\CoreBundle\Component\SQLSearchEngine
> class_options:
> connection: ine_06112014
> relation: entidad
> attributes:
> - gid
> - entidad
> geometry_attribute: geom
> form:
> entidad:
> type: text
> options:
> required: false
> label: Entidad
> compare: exact
> results:
> view: table
> count: true
> headers:
> entidad: Entidad
> callback:
> event: click
> options:
> buffer: 1000
> minScale: null
> maxScale: null
> styleMap:
> default:
> strokeColor: '#00ff00'
> strokeOpacity: 1
> fillOpacity: 0
> select:
> strokeColor: '#ff0000'
> fillColor: '#ff0000'
> fillOpacity: 0.8
> <http://osgeo-org.1560.x6.nabble.com/file/t378095/001.jpg>
> <http://osgeo-org.1560.x6.nabble.com/file/t378095/002.jpg>
> <http://osgeo-org.1560.x6.nabble.com/file/t378095/003.jpg>
> <http://osgeo-org.1560.x6.nabble.com/file/t378095/004.jpg>
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Where2B Konferenz 2017
14. Dezember 2017 in Bonn
www.where2b-conference.com
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
