[Mapbender-users] Difference in app.php and app_dev.php?
Teresa Graßl teresagrassl91 at gmail.com
Wed Sep 27 05:48:43 PDT 2017
Hello,
I´m confused about two parts of MapBender. I created a new application
under *http://localhost/mapbender3/manager/applications
<http://localhost/mapbender3/manager/applications>.* When I add the element
digitizer (please see added e-mail) in my content-part of layouts and
connect my database, following error occurs by starting the application:
*​Feature API query error."<!DOCTYPE html>\n<html>\n <head>\n <meta
charset=\"UTF-8\" />\n <title>An Error Occurred: Internal Server
Error</title>\n </head>\n <body>\n <h1>Oops! An Error Occurred</h1>\n
<h2>The server returned a \"500 Internal Server Error\".</h2>\n\n <div>\n
Something is broken. Please let us know what you were doing when this error
occurred.\n We will fix it as soon as possible. Sorry for any inconvenience
caused.\n </div>\n </body>\n</html>\n"*
I read in a forum comment, that one solution is to start the application in
the developement mode under
*http://localhost/mapbender3/app_dev.php/manager/applications
<http://localhost/mapbender3/app_dev.php/manager/applications>*. By doing
this, the element digitizer works fine and no errors occur by starting the
application. But now: by editing any element "button" (layouts -> toolbar)
an error occurs:* internal server error*. Other elements in the toolbar as
well as in the content and footer can by edited without problems. Only the
element "button" does not work. The tricky thing is, that working
<http://localhost/mapbender3/manager/applications>* all elements "button"
are working fine and are easily editable.
For the use of my application, I don´t want to open it in the developement
mode! Do you know, why the both modes are acting so differnt? Do I have to
do special or additional configurations? Which mode is best for using it
and modifying an application?
Thank you so much in advance!
Best regards
Teresa
---------- Forwarded message ----------
Date: 2017-09-22 16:01 GMT+02:00
Subject: Re: [Mapbender-users] Mapbender don´t show map
To: Mapbender User List <mapbender_users at lists.osgeo.org>
Hello Charlotte,
maybe you can help me again.
I´ve added the element "digitizer" and entered following yml-file:
*bohrdaten:    label: Punkt Digitalisierung    inlineSearch: true
maxResults: 500    featureType:        connection: Bohrpunkte_NP
table: bohrdaten        uniqueId: id        geomType: point
geomField: geom        srid: 4326    openFormAfterEdit: true
zoomScaleDenominator: 500    allowEditData: true    allowDelete: true
allowDigitize: true    useContextMenu: true    useCancelButton: true
toolset:        - type: drawPoint        - type: moveFeature
popup:        title: Editieren Bohrpunkte         width: 500px
searchType: currentExtent    tableFields:        id: {label: Nr.}
projektnummer: {label: Projekt}        adresse: {label: Adresse}
beschreibung: {label: Beschreibung}        datum: {label: Datum}
gw_flurabstand: {label: GW-Flurabstand [m]}        gw_maechtigkeit: {label:
GW-Mächtigkeit [m]}        gok: {label: GOK [m ü. NN]}        gwo: {label:
GWO [m ü. NN]}        tertiaer_ok: {label: Tertiär-OK [m ü. NN]}
erschliessung: {label: Erschließung}        nutzung: {label: Nutzung}
styles:        default:            strokeWidth: 2            strokeColor:
'#0e6a9e'            fillColor: '#1289CD'            fillOpacity:
1            fillWidth: 2            pointRadius: 10
select:            strokeWidth: 3            strokeColor:
'#0e6a9e'            fillOpacity: 0.7            pointRadius: 10
formItems:       - type: tabs         children:           - type:
form             title: Basisinformationen             css: {padding:
10px}             children:                 - type: label
title: Hier kannst du einen neuen Bohrpunkt erfassen!                 -
type: input                   title: Projekt                    mandatory:
true                   name: projektnummer                   mandatoryText:
Hoppla. Unvollständige Eingabe!                   infoText: "Bitte gib eine
Projektnummer an!"                   placeholder: "z.B. 1234 oder
1234-1"                 - type: textArea                   title:
Adresse                   name: adresse                   rows:
2                 - type: select                   title:
Erschließung                   name: erschliessung
multiple: false                   options: {1: Rammsondierung, 2:
Kleinbohrung, 3: Bohrung}                   infoText: "Hier kann angegeben
werden, wie der Bohrpunkt erschlossen wurde"                 - type:
select                   title: Nutzung                   name:
nutzung                   multiple: false                   options:
{1:Erkundung, 2:GWM, 3:Geothermie}                   infoText: "Hier kann
angegeben werden, wie der Bohrpunkt genutzt wird"                 - type:
input                   title: Beschreibung                   name:
beschreibung                   mandatory: false
placeholder: "Hier können zusätzliche Informationen angegeben
werden."                 - type: date                   title:
Datum                   name: datum                    placeholder: "z.B.
01.01.2017"                   dateFormat: dd.mm.yy
infoText: "Das Datum wird im Format dd.mm.yy angegeben."           - type:
form             title: Details             css: {padding:
title: Bitte gib hier weitere Informationen zum Bohrpunkt
an!                 - type: fieldSet
children:                       - type: input
title: GW-Flurabstand [m]                         name:
gw_flurabstand                         css: {width:
33%}                       - type: input                         title:
GW-Mächtigkeit [m]                         name:
gw_maechtigkeit                         css: {width:
33%}                       - type: input                         title: GWO
[m ü. NN]                         name: gwo                         css:
{width: 33%}                 - type: fieldSet
title: GOK [m ü. NN]                         name:
gok                         css: {width: 50%}                       - type:
input                         title: Tertiär-OK [m ü. NN bzw. m unter
GOK]                         name: tertiaer_ok                         css:
{width: 50%}*
I added two database-connection to my config.yml and my parameters.yml
(like explained in https://doc.mapbender3.org/de/book/database.html):
1) in the config.yml
*doctrine:    dbal:        default_connection: default
connections:            # Datenbankverbindung default
default:                driver:   %database_driver%
host:     %database_host%                port:
%database_port%                dbname:   %database_name%
path:     %database_path%                user:
%database_user%                password: %database_password%
persistent: true                charset:  UTF8                logging:
%kernel.debug%                profiling: %kernel.debug%            #
Datenbankverbindung Bohrpunkte_NP            Bohrpunkte_NP:
driver:   %database2_driver%                host:
%database2_host%                port:     %database2_port%
dbname:   %database2_name%                path:
%database2_path%                user:     %database2_user%
password: %database2_password%                persistent:
%kernel.debug%                profiling: %kernel.debug%*
2) In the parameters.yml
*parameters:    # Datenbankverbindugn default    database_driver:
pdo_pgsql    database_host:     localhost    database_port:     5432
database_name:     mapbender3    database_path:     ~    database_user:
postgres    database_password: ****    #Datenbankverbindung
Bohrpunkte_NP    database2_driver:   pdo_pgsql    database2_host:
localhost    database2_port:     5432    database2_name:
Bohrpunkte_NP    database2_path:     ~    database2_user:     postgres
database2_password: ****        mailer_transport:  smtp
mailer_host:       localhost    mailer_user:       ~    mailer_password:
After updating and return to my application following error occured:
*​​Feature API query error."<!DOCTYPE html>\n<html>\n <head>\n <meta
When I import my application in the develover environment
*http://localhost/mapbender3/app_dev.php/application/bp
<http://localhost/mapbender3/app_dev.php/application/bp>* and open my
application, everything´s working (no error). So I´m confused, why in the
app_dev.php it works, but not at the frontend
*http://localhost/mapbender3/application/bp
<http://localhost/mapbender3/application/bp>*? Do I have to do special oder
Thank you in advance and have a nice weekend
Cheers,
Teresa
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170927/b7f8bfff/attachment-0001.html>
More information about the Mapbender_users mailing list
