[Mapbender-users] Mapbender 3.0.7.3 released
Axel Schaefer axel.schaefer at wheregroup.com
Fri Jul 13 05:47:43 PDT 2018
Dear Mapbender Users and Mapbender Developers
You'll find the German version of this announcement below.
Mapbender version 3.0.7.3 is released and available at
http://www.mapbender.org.
The Feature-Release contains a lot of minor bugfixes, medium
code-changes and major functions: One is the compatibility to QGIS
Server WMS services (and other not-named server software) which use
another layer-order in their capabilities. Further deatils are in the
documentation:
https://doc.mapbender.org/en/functions/backend/layerset.html
We've added the Coordinate Utility
(https://doc.mapbender.org/en/functions/misc/coordinate_utility.html) as
a module from within its own repository
(https://github.com/mapbender/coordinates-utility). The element itself
allows you to grab coordinates from the map or zoom to a specific
location. The module itself is, like the Digitizer beforehand, written
as an external module using the new module API to connect new
functionality to Mapbender.
Under the hood we fixed a lot of bugs and streamlined some code, made
steps for the integration of OL4 and for working with next functionality
like a Routing interface. To speak of OpenLayer4: We have taken a huge
step in developing the API into Mapbender and we've documented the
effort on our Mapbender page (where you can contibute and sponsor the
next steps): https://mapbender.org/?q=en/sponsoring-en
The documentation is available at http://doc.mapbender.org. We have
adjusted the structure and put additional information to some
elements. This was a huge step to lead the documentation to a more
user-documentation and to leave out the developer-parts (which are in
the Contributing Guide in the source-code itself). The Tipps & Tricks
section will be filled with aditional small helper texts. If you know a
good Trick, keep us informed. ;-)
A note about the version number: Version 7.0, 7.1 and 7.2 were not
released due to tagging errors on our Github page. Since it's not a good
idea to retag code, we decided to leave these tags and release the
proper version now with 3.0.7.3. Next feature release will be tagged
with RC tags prior to the final release.
And as always: Thank you all for your participation, especially the
Mapbender Core-Team, who did a great job and to all the new developers.
Please refer to the versions-log at the Mapbender3 documentation
(http://doc.mapbender.org/en/versions.html) for details.
Please keep an eye on the additional steps to update this version and
the database-scheme.
- Download: http://www.mapbender.org/?q=en/download or via http://www.mapbender.org/builds/
- Source code:https://github.com/mapbender/mapbender-starter
- Contributing.md for developers:
  https://github.com/mapbender/mapbender-starter/blob/master/CONTRIBUTING.md
- Report bugs: https://github.com/mapbender/mapbender/issues
- Current Documentation: http://doc.mapbender.org/
- Installation and Update:
  http://doc.mapbender.org/en/installation.html
- Quickstart: http://doc.mapbender.org/en/quickstart.html
- Mapbender-demo: https://demo.mapbender.org/
- Sandbox: https://sandbox.mapbender.org/
Thanks to all participants.
German Version: Liebe Mapbender-Benutzer und Mapbender-Entwickler
Die Mapbender Version 3.0.7.3 is verfügbar unter http://www.mapbender.org.
Dieses Feature Release enthält einige kleine Bugfixes, mittelgroße
Code-Änderungen und große Funktionen. Eine ist die Kompatibilität zu
QGIS Server WMS Diensten (und anderer nicht genannter Server Software),
die eine andere Layer-Reihenfolge in ihren Capabilities nutzen. Mehr
Informationen findet sich in der Dokumentation:
https://doc.mapbender.org/de/functions/backend/layerset.html
Wir haben das Koordinaten-Utility
als Modul aus dem eigenen Repository
(https://github.com/mapbender/coordinates-utility) hinzugefügt. Das
Element erlaubt Ihnen die Koordinaten aus der Karte abzugreifen oder zu
einer spezifischen Koordinate zu springen. Das Modul selbst ist, wie der
Digitizer, als externes Modul geschrieben und nutzt die neue Modul-API
um sich in den Mapbender einzubinden und dessen Funktionalität zu
nutzen.
Unter der Haube haben wir einige Bugs gefixt und den Code geradegezogen;
Schritte, die für die Integration von OpenLayers4 und für die weiteren
Funktionen, wie beispielsweise ein Routing-Interface, notwendig sind. Um
bei OpenLayers4 zu bleiben: Wir haben große Schritte unternommen, um die
API in den Mapbender zu integrieren und den Fortschritt auf unserer
Webseite dokumentiert (wie Sie uns auch gerne unterstützen können und
sich am Sponsoring beteiligen):
https://mapbender.org/?q=de/sponsoring-de
Die Dokumentation ist unter http://doc.mapbender.org verfügbar. Wir
haben dort die Struktur angepasst und einige Elemente mit erweiterten
Inhalten gefüllt. Das war ein großer Schritt hin zu einer
transparenteren Benutzerdokumentation, was auch bedeutet, dass die
Entwicklerteile sich in dem Contributing Guide im Code selbst
befinden. Die Tipps & Tricks Sektion wird mit kleinen Helferlein weiter
ausgebaut. Wenn Sie einen guten Trick kennen, schreiben Sie uns an. :-)
Eine Anmerkung zur Versionsnummer: Version 7.0, 7.1 und 7.2 wurden
aufgrund von Fehlern im Tagging auf GIthub nicht offiziell
veröffentlicht. Da es nicht gut ist, wenn man den Code re-tagged, haben
wir uns entschlossen diese Tags beizubehalten und eine richtige Version
nun mit dieser 3.0.7.3 zu veröffentlichen. In den nächsten Releases
werden wir RC-Tags verwedenet, bevor es den finalen Release gibt.
Und wie immer: Danke an alle Beteiligten, speziell das Mapbender
Kernteam, die einen tollen Job gemacht haben und an alle neuen
Entwickler.
Bitte schauen Sie in das Versions-Log in der Mapbender3 Dokumentation
für Details: http://doc.mapbender.org/de/versions.html.
Bitte beachten Sie auch die zusätzlichen Schritte zum Update der Version
und des Datenbank-Schemas.
- Download: http://www.mapbender.org/?q=de/download oder über http://www.mapbender.org/builds/.
- Source-Code: https://github.com/mapbender/mapbender-starter
- Contributing.md für Entwickler:
- Melden von Fehlern: https://github.com/mapbender/mapbender/issues
- Dokumentation: http://doc.mapbender.org/
- Installation und Update:
  http://doc.mapbender.org/de/installation.html
- Quickstart: http://doc.mapbender.org/de/quickstart.html
- Mapbender-Demo: https://demo.mapbender.org/
Vielen Dank an alle Beteiligten.
Best regards / Mit freundlichen Grüßen
Axel Schaefer
Axel Schaefer
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 23
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com | www.mapbender.org
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
