[Mapbender-users] Mapbender and PHP 7.2
Axel Schaefer
axel.schaefer at wheregroup.com
Wed Jun 13 04:50:22 PDT 2018
Hello.
For the forthcoming release we are nibbeling with the PHP 7.2
compatibility and will therefore give two hints:
1.) For the release we will remove the apigen library (which is in the
dev-section) and try to provide the API by hand. The Mapbender
release will unfortunately not have the API-documentation.
2.) If you develop and install via Git, do it with composer install
--no-dev or composer update --no-dev. Or remove the apigen line from
composer.json and run composer update.
Otherwise the 7.2 compatibility in Mapbender looks good. It's the
libraries that took action. Apigen requires Nette/nette and although
Nette has fixed the 7.2 compatibility, Apigen now requires either
Symfony 2.6 or Symfony 3.3. We use 2.8.
Best regards
Axel
More information about the Mapbender_users
