[Mapbender-users] Digitizing several groups of polygons
Charlotte Toma (WhereGroup)
charlotte.toma at wheregroup.com
Fri Jun 22 10:50:39 PDT 2018
Hi Hannah,
you can add multiple digitizer-elements in one application and in each
digitizer-elment you can define a unlimited number of surfaces for the
data collection.
For your workflow you should do this:
* add digitizer with name "land-use" and for each land-use one scheme,
e.g. "forest", "street", ...
* add second digitizer with name "projekt" and there you can add more
schemes
The code should look like this (important is the unique name of the
scheme):
landuse_forest:
label: 'Land-use FOREST'
featureType:
connection: search_db
table: landuse_forest
uniqueId: gid
geomType: polygon
geomField: geom
srid: 4326
toolset: [...]
popup: [...]
tableFields: [...]
styles: [...]
formItems: [...]
landuse_street:
label: 'Land-use STREETS'
featureType:
table: landuse_street
uniqueId: gid
geomType: polygon
geomField: geom
srid: 4326
toolset: [...]
popup: [...]
tableFields: [...]
styles: [...]
formItems: [...]
second digitizer with definition of project-schemes:
projekt_poi:
featureType:
table: poi
uniqueId: gid
geomType: polygon
geomField: geom
srid: 4326
toolset: [...]
popup: [...]
tableFields: [...]
styles: [...]
formItems: [...]
projekt_line:
featureType:
table: line
uniqueId: gid
geomType: line
geomField: geom
srid: 4326
toolset: [...]
popup: [...]
tableFields: [...]
styles: [...]
formItems: [...]
The other option is to make one big digitizer-scheme for landuse and one
field in this digitizer-formular for the classification via a selecbox
(with forest, street, ...).
You can't use one digitizer-scheme for diffrent geometry types.
Greetings
Charly
Am 2018-06-22 16:04, schrieb Hannah Seeger:
> Hello Mailing-List!
> I have a question concerning the digitizer element: is it possible to
> split the feature types (point/line/polygon digitizing) in multiple
> groups?
> I need to draw several groups of polygons with different formulars:
> e.g. one polygon-group for "land-use" objects that can be classified
> in several categories, another polygon-group containing "project"
> objects that are as well classified in several categories, and so on.
> In the YAML-definition in the textarea schemes I've tried to copy,
> paste and adapt the "polygon-code" for the different groups needed,
> but unfortunately this is not working (it only appears one group for
> polygon-digitizing).
> Is there a possibility to do this?
> Thanks a lot in advance!
> Hannah
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
