[Mapbender-users] spatial search and file upload
Astrid Emde astrid.emde at wheregroup.com
Thu Jun 28 01:35:28 PDT 2018
Hello Max,
thanks for your mail.
Am 2018-06-26 15:24, schrieb Max Müller:
> Hello everyone!
> I have two questions (sorry, my English is not the best, hope you can
> unterstand anyway):
> 1. Is it possible with mapbender3 to make a "spatial search" or select
> by polygon? I've read it was possible with mapbender2 but cannot find
> how you do it now, only Simple Search and Search Router.
Yes it was possible with Mapbender2 and would be great if Mapbender3
would support this feature too.
But at the moment SearchRouter and SimpleSearch do not support it. I
would suggest to add this as functionality to SearchRouter. But we need
someone to sponsor this feature. So if you have the possibility do it
you are very welcome.
> 2. File Upload: we managed to establish the Image, PDF and Movie
> upload in the Digitizer and the upload works.
Sounds good.
> But can I display the
> PDFs and Movies somehow like images? Is there a special type for the
> yaml code or a possibility to link them or another file where to
> change the code?
Looks like you have to add more functionality to the vis-ui.js form
generator from eSlider (Andriy Oblivantsev). It is integrated in the
Mapbender project now and was separate before
(https://github.com/eSlider/vis-ui.js)
https://github.com/mapbender/vis-ui.js/blob/master/src/js/jquery.form.generator.js#L397
If you would like to generate a link you could use a text file and get
your column via data.href and generate a JavaScript function that will
display a link.
Astrid
> Greetings,
> Max
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Senior GIS-Consultant
AGIT 2018
4.- 6. Juli 2018 in Salzburg
Treffen Sie die WhereGroup bei der AGIT EXPO
http://www.agit.at/
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
