[Mapbender-users] [mapbender/mapbender] Search Router - Templates crashes with quotes (#246)
    Astrid Emde
    astrid.emde at wheregroup.com
    Fri May 18 05:14:53 PDT 2018
yes Mapbender can run with PostgreSQL 9.5
1.) Please open your Mapbender in app_dev-mode to find the problem.
http://localhost(mapbedner3/app_dev.php
This mode gives back better feedback, when an error occurs.
2. Please check your parameters.yml and config.yml
a) please test Mapbender first without searchRouter -> is it working?
b) add the second database to parameters.yml and config.yml  -> check
for valid yaml-syntax with http://www.yamllint.com/
Find help here
https://doc.mapbender.org/en/book/database.html
https://doc.mapbender.org/de/bundles/Mapbender/CoreBundle/elements/search_router.html
Am 2018-05-18 11:28, schrieb KOUASSI Urbain:
> Hello,
> Is Mapbender3 really compatible with postgresql?
> Or is the Mapbender3 version compatible with postgresql 9.5? because
> the version of postgres I'm currently using.
> You are receiving this because you modified the open/close state.
> Reply to this email directly, view it on GitHub [1], or mute the
> thread [2].
> Links:
> [1]
> https://github.com/mapbender/mapbender/issues/246#issuecomment-390150732
> [2]
> https://github.com/notifications/unsubscribe-auth/AA8zyp5hUcCa6wT1KQ7OnzexhGOazLXyks5tzpQrgaJpZM4CXqm2
Mit freundlichen Grüßen
Astrid Emde
Senior GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
