[Mapbender-users] Filing issues in Github
    Axel Schaefer
    axel.schaefer at wheregroup.com
    Fri May 25 02:59:56 PDT 2018
Hi.
Github has introduced templates to file bugs or features. We activated
them and wait for the merge request (which is then in a .github
directory in the code)
The PR is here: https://github.com/mapbender/mapbender/pull/839/files
A Bug template will look like this:
| about: Create a report to help us improve
| **Describe the bug**
| A clear and concise description of what the bug is.
| **To Reproduce**
| Steps to reproduce the behavior:
| 1. Go to '...'
| 2. Click on '....'
| 3. Scroll down to '....'
| 4. See error
| **Expected behavior**
| A clear and concise description of what you expected to happen.
| **Versions (please complete the following information):**
|  - Mapbender: [e.g. 3.0.6.3]
|  - Database: [e.g. PSQL 9.5.12]
|  - Browser [e.g. chrome, safari]
| **Screenshots / Logmessage**
| If applicable, add screenshots or a logmessage from app/logs to help explain your problem.
| **Additional context**
| Add any other context about the problem here.
A feature request like this:
| about: Suggest an idea for this project
| **Is your feature request related to a problem? Please describe.**
| A clear and concise description of what the problem is. Ex. I'm always frustrated when [...]
| **Describe the solution you'd like**
| A clear and concise description of what you want to happen.
| **Describe alternatives you've considered**
| A clear and concise description of any alternative solutions or features you've considered.
| Add any other context or screenshots about the feature request here.
The changes will be visible next week.
Axel
Axel Schaefer
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 23
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com | www.mapbender.org
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
