[Mapbender-users] Add WMS Source results in a 500 server error
Peter Sykora
peter_sykora at gmx.at
Mon Oct 8 11:56:02 PDT 2018
Hi David, hi Astrid
thanks for the quick reply!
I think that I have already installed the correct version of curl when I ran
the command mentioned in the installation instructions:
# apt install php5 php5-gd php5-curl php5-cli php5-sqlite sqlite php5-intl
php5-mbstring curl openssl
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package php5-mbstring
php --info gives me:
curl
cURL support => enabled
cURL Information => 7.35.0
Age => 3
Features
AsynchDNS => Yes
CharConv => No
Debug => No
GSS-Negotiate => Yes
IDN => Yes
IPv6 => Yes
krb4 => No
Largefile => Yes
libz => Yes
NTLM => Yes
NTLMWB => Yes
SPNEGO => No
SSL => Yes
SSPI => No
TLS-SRP => Yes
Protocols => dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap,
ldaps, pop3, pop3s, rtmp, rtsp, smtp, smtps, telnet, tftp
Host => x86_64-pc-linux-gnu
SSL Version => OpenSSL/1.0.1f
ZLib Version => 1.2.8
When I run your command I get the curl libraries for php7, and I still get
the same error messages....
Could the missing php5-mbstring library be a problem? I don't really
understand why the package isn't available. I'm running Ubuntu 14
@Astrid:
no, none of the WMS work, I always get the same error messages.
As I already mentioned php5-mbstring is missing and I run php 5.5.9 - but
this configuration works on my notebook as well.
Should I upgrade to php 5.6 or even 7?
Cheers
Peter
Am 08.10.2018 um 14:30 schrieb David Patzke:
> Hi Peter,
> you need to install curl on your server. (sudo apt-get install php-curl)
> Cheers
> David
Astrid Emde (WhereGroup) wrote
> Hello Peter,
> make sure with a test in the browser that the WMS exists:
> Version 1.3.0 will show the getCapabilities XML in the browser. Version
> 1.1.1 will give the XML for download.
> Please try this WMS and give feedback:
> https://wms.wheregroup.com/cgi-bin/mapbender_user.xml?VERSION=1.3.0&REQUEST=GetCapabilities&SERVICE=WMS
> And please check whether the system requirements are fulfilled
> https://doc.mapbender.org/en/installation/systemrequirements.html
> Astrid
Sent from: http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
More information about the Mapbender_users
