[Mapbender-users] Upgrade help
Astrid Emde
astrid.emde at wheregroup.com
Fri Sep 21 00:10:50 PDT 2018
Hello Zsolt,
Am 2018-09-21 06:04, schrieb Gal Zsolt:
> Hello to everybody
> I make on upgrade on Linux from 3.0.6.3 to 3.0.7.4.
Did you follow the upgrade description:
https://doc.mapbender.org/en/installation/update.html
> Mapbender work but vesion number is same 3.0.6.3, and I don't see my
> applications.
If you still use the parameters.yml from your 3.0.6.3 installation you
will find the version number that is defined in the file.
Check parameters.yml-dist file for the version and edit it in your
parameters.yml file.
> Where and what I do wrong?
> From the upgrade process, I don't understand the
> # merge parameters.yml, config.yml and if used mapbender.yml
> I don't understand how to do this? I copy the old to new but how to
> merge?
Check whether there are new variables or definitions in the files. It
always can happen, that we define new variables in the configuration
files. Therefore you have to make sure, that they are in your file
aswell.
> How must I log to Linux to make the upgrade?
see https://doc.mapbender.org/en/installation/update.html
> I will appreciate any help and thanks for it.
Also make sure to
* update your database with app/console doctrine:schema:update --force
* export the web directory app/console assets:install web
* clear cache
* have a look at your application in developer mode app_dev.php
* use F12 to check for errors
Best
Astrid
> Zsolt
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
Senior GIS-Consultant
INTERGEO 2018
16.- 18. Oktober 2018 in Frankfurt am Main
Treffen Sie die WhereGroup an Stand 12.0A.29 in Halle 12.0
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
