[Mapbender-users] Mapbender 3.0.8 released 2019-04-12
    Astrid Emde (WhereGroup)
    astrid.emde at wheregroup.com
    Fri Apr 12 03:38:31 PDT 2019
See german version below
============ english =================
Dear Mapbender-Users and Mapbender-Developers,
on 2018-04-12 we published version 3.0.8 of Mapbender. Thanks to all
people involved!
This version is a long-term-support version (LTS version) with some new
features and several bugfixes. We will provide security fixes for the
LTS verson till 2021-03-31.
Please refer to changelog to find out about the changes [1]
Download: https://mapbender.org/?q=en/download or directly via the link
[2].
Tag v3.0.8 at GitHub [3]
https://github.com/mapbender/mapbender-starter/releases/tag/v3.0.8
There are some changes in the database. So please please call the
doctrine:schema:update command to update the database. See
documentation: https://doc.mapbender.org/en/installation/update.html
If you would like to work and develop with the source code read the
Developer Guide (Contributing.md) [4]:
https://github.com/mapbender/mapbender-starter/blob/master/CONTRIBUTING.md
Report bugs [5]: https://github.com/mapbender/mapbender/issues
Documentation [6]: https://doc.mapbender.org/en/
Installation and Update: https://doc.mapbender.org/en/installation.html
Try Mapbender and follow the Mapbender quickstart
https://doc.mapbender.org/en/quickstart.html
Mapbender-demo [7] https://demo.mapbender.org/
The Mapbender team is working on the next version 3.1. We plan to
publish this version in 2019. This version will use OpenLayers 4 and
will provide a responsive design. This is the biggest change of the last
years for the software. The Team says thank you to all the sponsors for
the financial support and to the community. Sponsors for Mapbender 3.1
are Vattenfall, Stromnetz Hamburg and City of Gütersloh and City of
Troisdorf.
Best regards
Mapbender Team
============= deutsch ===============
Hallo Mapbender-Community,
das Mapbender-Entwicklungsteam hat die Mapbender-Version 3.0.8. am
12.8.2019 veröffentlicht. Herzlichen Dank an alle Beteiligten.
Es handelt sich bei dieser Version um eine Long-Term-Support-Version
(LTS-Version).
Der Schwerpunkt wurde hier auf Stabilität und Performanz gelegt.
Zahlreiche kleinere Bugs wurden gefixt, mehrere neue Features der
letzten Versionen optimiert und alles umfangreich getestet.
Highlights der neuen Version sind u.a. :
Performanz, Sicherheit und Einbindung wurden verbessert für den
Dimensionhandler, das Redlining, die Einbindung von Funktionen in das
Sidepane und das Mobile Template.
Das neue Feature in der Druck-Engine, die Warteschleife für
Druckaufträge, ermöglicht den Druck von A0 auch ohne Print-Server.
Außerdem werden große Legendenbilder besser skaliert und mehrzeilige
Fließtexte in Freifelder und Titel unterstützt.
Layer-Titel können beim WMS-Reload nun automatisch aktualisiert werden.
Alle Überarbeitungen im Detail können dem Change-Log [1] entnommen
werden. Insgesamt handelt es sich um über 50 Enhancements und Fixes.
Die Version 3.0.8. wird als LTS-Version bis zum 31.03.2021 mit
Sicherheitsaktualisierungen versorgt.
Für 2019 ist außerdem die Veröffentlichung der Mapbender-Version 3.1
vorgesehen. Damit verbunden ist die Anhebung des Kartenframeworks auf
OpenLayers 4 und ein Responsive Design geplant. Dies ist die größte
Veränderung der Software der letzten Jahre. Das Team bedankt sich an
dieser Stelle für die finanzielle Unterstützung, die es aus der
Community gab. Dazu gehören u. a. Vattenfall, Stromnetz Hamburg sowie
die Städte Gütersloh und Troisdorf.
Download 3.0.8: http://mapbender.org/?q=de/download oder direkt unter
[2].
Tag v3.0.8 auf GitHub [3]
Es liegen ein paar Änderungen in der Datenbank vor. Führen Sie daher
doctrine:schema:update durch. Siehe Dokumentation:
https://doc.mapbender.org/de/installation/update.html
Helfen Sie mit Mapbender weiterzuentwickeln: Developer Guide
Melden Sie Bugs [5]: https://github.com/mapbender/mapbender/issues
Dokumentation [6]: https://doc.mapbender.org/de/
Informationen zur Installation und Aktualisierung auf eine neue Version:
http://doc.mapbender.org/de/installation.html
Probieren Sie Mapbender aus. Es gibt ein Mapbender-Tutorial, das die
ersten Schritte mit Ihnen durchgeht:
https://doc.mapbender.org/de/quickstart.html
Probieren Sie die neue Version direkt aus: Mapbender-Demo [7]
Viel Spaß mit der neuen Version wünscht
Das Mapbender Team
Links
[1] https://github.com/mapbender/mapbender/releases
[2] https://www.mapbender.org/builds/mapbender-starter-current.tar.gz
[3] https://github.com/mapbender/mapbender-starter/releases/tag/v3.0.8
[4]
[5] https://github.com/mapbender/mapbender/issues
[6] https://doc.mapbender.org/
[7] Mapbender-Demo: https://demo.mapbender.org/
More information about the Mapbender_users
