[Mapbender-users] WG: HTML-Legend in Mapbender 2.7
Armin Retterath
armin.retterath at gmail.com
Mon Apr 29 12:46:56 PDT 2019
hi patrick yes - we develop the old mapbender 2.x trunk ;-) - it is the
only good metadata solution for solving the demands of the inspire
directive.
our goal is to reengineer the mapbender backend (service registry /
metadata management & search / security / inspire) with django.
the code can be found here:
https://git.osgeo.org/gitea/armin11/GeoPortal.rlp
best regards,
armin
Am Mo., 29. Apr. 2019 um 14:26 Uhr schrieb Patrick Meis <
Meis at stadt-muenster.de>:
> Hello Armin,
> now I get it, you guys are still developing the 2.x trunk, right?
> Well, this HTML-legend would defnitely be a "nice to have" in our
> Mapbender.
> But its not really urgent, like we need it this week.
> Best regards
> Patrick
> -----Ursprüngliche Nachricht-----
> Von: Armin Retterath [mailto:armin.retterath at vermkv.rlp.de]
> Gesendet: Freitag, 26. April 2019 11:58
> An: Mapbender User List; Patrick Meis
> Betreff: Re: [Mapbender-users] HTML-Legend in Mapbender 2.7
> [DOI-Mail]:
> Diese Mail haben Sie über das Behördennetz DOI erhalten.
> hi pascal,
> it is not yet implemented - but it should not be to difficult ;-) - maybe
> 1 hour ?
> https://trac.osgeo.org/mapbender/browser/trunk/mapbender/http/javascripts/mod_legendDiv.php
> maybe some further objects should be extended - in our database there are
> no legendurl elements with pdf or html mimetypes ;-)
> (1400 services registrated)
> by when do you need this little feature?
> i extended the map/layer object last week for couplings between layers and
> featuretypes and i think i remember where to fix it.
> best regards
> armin
> > Patrick Meis <Meis at stadt-muenster.de> hat am 26. April 2019 um 11:32
> geschrieben:
> > Hello Armin,
> > thanks for your help.
> > And you are right, I should present a more extensive description of my
> problem.
> > I have a raster layer of the german "Flächennutzungsplan", a raster
> layer. Which has a rather big Legend in Pdf-format:
> > https://geo.stadt-muenster.de/webgis2/html/fnp/legende_fnp.pdf
> > I would like to create a link to this Pdf in my Mapbender legend.
> > Something like shown here:
> http://demo.mapserver.org/cgi-bin/mapserv?map=%2Fosgeo%2Fmapserver%2Fitasca_legend%2Fmap%2Fitasca3.map&layers=all&zoomsize=2&zoomdir=1&map_size=600+400&map_web=
> > (for example the Airport-link leads tot he Pdf).
> > But i am not sure if Mapbender can work with a legend sent in HTML and
> not in Png.
> > Patrick
> > Gesendet: Freitag, 26. April 2019 10:23
> > [DOI-Mail]:
> > hi pascal,
> > can you check if the legend handling like in
> > http://www.geoportal.rlp.de/portal/karten.html (mapbender 2.x trunk)
> > is that what you want? you can define legends in mapserver for raster
> and vector data. mapbender calls the legendurl (mapserver set this to a
> getlegendgraphic url !) by every getmap invocation. therefor the legend
> shows only the vector layers, that are visible. the raster legend is
> hardcoded.
> > maybe you can give some more info about you demands ;-)
> > best regards
> > armin
> > > Patrick Meis <Meis at stadt-muenster.de> hat am 26. April 2019 um 09:49
> geschrieben:
> > > Von: Patrick Meis
> > > Gesendet: Donnerstag, 25. April 2019 11:14
> > > An: Mapbender_users
> > > Betreff: HTML-Legend in Mapbender 2.7
> > > Hello group,
> > > is it possible to use a HTML-legend for a WMS in Mapbender 2.7, as
> described in the documentation for Mapserver:
> > > https://mapserver.org/de/output/html_legend.html#html-legend
> > > Im not able to find any examples for it in the web, but i did find an
> old Email in this group that it was not possible in 2008:
> https://lists.osgeo.org/pipermail/mapbender_users/2008-April/002003.html
> (only in german)
> > > Maybe something changed? Does anybody know?
> > > Thanks for any help
> > > Patrick
> > > diesmalw?hleich.eu<https://www.diesmalwaehleich.eu>
> > > Am 26. Mai 2019 ist Europawahl
> > > Der Schutz Ihrer personenbezogenen Daten ist der Stadt M?nster ein
> wichtiges Anliegen. Die Datenschutzerkl?rung finden Sie unter folgendem
> Link: https://www.stadt-muenster.de/datenschutz.html
> > > _______________________________________________
> > > Mapbender_users mailing list
> > > Mapbender_users at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/mapbender_users
> > diesmalwähleich.eu <http://xn--diesmalwhleich-dib.eu><
> > Der Schutz Ihrer personenbezogenen Daten ist der Stadt Münster ein
> wichtiges Anliegen. Die Datenschutzerklärung finden Sie unter folgendem
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20190429/27d048db/attachment.html>
More information about the Mapbender_users
