[Mapbender-users] Fwd: MS4W version 4.0.0-beta1 available
Astrid Emde
astrid.emde at wheregroup.com
Wed Feb 6 06:12:48 PST 2019
Great!
Thanks a lot
Astrid
Am 2019-02-06 14:38, schrieb Jeff McKenna:
> Thanks Astrid, I have also integrated 3.0.7.7 into the stable MS4W
> 3.3.0 release: https://ms4w.com/release/ms4w-3.3.0-setup.exe
> -jeff
> On 2019-02-05 2:35 AM, Astrid Emde wrote:
>> Hello Jeff,
>> thanks for integrating the actual Mapbender 3.0.7.7 version to the
>> MS4W package. Great!
>> See you Astrid
>> Am 2019-02-05 02:43, schrieb Jeff McKenna:
>>> Forwarding the announcement below to the Mapbender community, as
>>> MS4W-4.0.0-beta1 contains a packaged Mapbender 3.0.7.7 Note that
>>> MS4W-4.0.0 contains PHP 7.2.14 and its performance enhancements are
>>> very noticeable.
>>> (I am aware that Mapbender does not officially support PHP 7.2.x yet,
>>> but this will give users and devs a Windows environment to test and
>>> help improve Mapbender for PHP 7.x)
>>> thanks, -jeff
>>> -------- Forwarded Message --------
>>> On 2019-02-04 8:46 PM, Jeff McKenna wrote:
>>>> Hello everyone,
>>>> Many Windows users will be very interested that MS4W-4.0.0-beta1 is
>>>> available now, which will be a huge release of changes, as every
>>>> library
>>>> (over 200 now) has been upgraded and built with a new compiler
>>>> (Visual Studio 2017), and contains many great additions overall.
>>>> You can test the beta at:
>>>> - installer:
>>>> https://ms4w.com/release/experimental/ms4w-4.0.0-beta1-setup.exe
>>>> (recommended)
>>>> - archive:
>>>> https://ms4w.com/release/experimental/ms4w_4.0.0_beta1.zip
>>>> Please see MS4W's HISTORY.txt for all of the changes, but here are
>>>> some of the highlights:
>>>> - Mapbox Vector Tile output through MapServer (demo included)
>>>> - PHP7 mapscript support (using the SWIG API)
>>>> - usual mapscripts available (Java, Python, CSharp)
>>>> - embedded Python 3.7.0
>>>> - running pycsw Catalogue Server
>>>> - expanded ZOO-Project WPS support (all GDAL/OGR services, Python,
>>>> PHP, CSharp, Java)
>>>> - new Matomo Analytics package
>>>> - simple map viewer on the localhost page
>>>> - GDAL 2.4.0
>>>> - MapServer 7.4.0-dev
>>>> - mod_wsgi for Apache
>>>> - and many more...
>>>> You can see that MS4W-4.0.0 will be a full SDI for Windows
>>>> environments, with ~40+ working mapfiles and over 1.7GB of files,
>>>> empowering DevOps and organizations worldwide. Also note that this
>>>> is a major release for MS4W, meaning that some things have changed
>>>> dramatically (PHPmapscript will now use the SWIG API for example),
>>>> so please follow MS4W's README for specific instructions for the
>>>> many plugins and mapscripts.
>>>> When installing, it is very important that (if you are using the
>>>> .zip) your server must have the C++ Redistributable installed on it
>>>> beforehand: execute the local file /ms4w/tmp/vcredist_x86.exe
>>>> (alternatively if you use MS4W's setup.exe installer this is done
>>>> automatically)
>>>> Please provide your 4.0.0 testing feedback through the MS4W tracker
>>>> (so the feedback is not lost or forgotten):
>>>> http://www.ms4w.com/trac/
>>>> Thank you all for sharing your spatial information with MS4W.
>>>> -jeff
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSS Academy Kompaktkurs "Winterschule 2019"
Grundwissen zum Aufbau von Geodateninfrastrukturen mit
Open-Source-Software
https://foss-academy.com/kompaktkurse
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
