[Mapbender-users] Highlight feature on click in mb3 ?
karsten
karsten at terragis.net
Wed Jan 16 02:33:01 PST 2019
Hi All,
I was trying to test thsi feature in teh MB 3.0.5 version and sucessfulyl
installed it. Now I tried to configure it but was not sure about this part
of the doumnetation in
https://github.com/mapbender/mapbender-documentation/blob/feature/featureinf
o-extension/en/bundles/Mapbender/CoreBundle/elements/feature_info_extension.
rst this says:
How to highlight the geometry
To use this functionality you have to extend your FeatureInfo-Template. It
needs a class="geometryElement", data-srid="EPSG:4326" with the information
about the projection of the data and data-geometry with the WKT presentation
of the geometry:
<table class="geometryElement" data-srid="EPSG:4326"
data-geometry="MULTIPOLYGON(...)" >...</table>
If you use PostgreSQL as datasource in your WMS Service, you can use the
PostGIS function st_asText(geom) to generate the WKT.
1. So if I use the PostGIS data source how would I go about to create the
WKT ? Would I create a view in teh DB and add a column 'WKT' by using
st_asText(geom) and add that as WMS to mapbender ?
2. In the FeatureInfo-Template if I did create the WKT via PostGIS what
wpould I need to refer to as "data-geometry" ?
How would the syntax look correctly ?
is it
<table class="geometryElement" data-srid="EPSG:4326" data-geometry="WKT"
>...</table>
Thanks
Karsten
-----Original Message-----
From: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] On
Behalf Of Astrid Emde
Sent: Monday, November 26, 2018 10:14
To: Mapbender User List
Subject: Re: [Mapbender-users] Highlight feature on click in mb3 ?
Hello Karsten,
there is one solution that can highlight results of a featureInfo (but is is
only working in an older Mapbender version 3.0.5.x)
rst
Would be great to have a funding to reactivate this feature in the actual
version of Mapbender.
Astrid
Am 2018-11-26 09:44, schrieb karsten:
> Hi all,
> in mapbender 3 is there a functionality to highlight a feature on
> click - for example that the user can indentify a WMS feature on the
> map and still see which one was clicked on.
> The only thing I found so far is the search functionality which has
> something kind of similar by adding a vector layer that shows all
> features found in teh search and the one selected form the result list
> Cheers
> Karsten Vennemann
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Where2B Konferenz 2018
13. Dezember 2018 im Universitätsclub Bonn Anmeldung & Infos:
https://where2b-conference.com/
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users
