[Mapbender-users] Mapbender Copy feature
Charlotte Toma
charlotte.toma at wheregroup.com
Wed Jan 23 00:58:25 PST 2019
Hello Lukas,
if you test this new function of the digitizer module in the developer
mode [1] an error message should appear (in the log file and application
interface).
The apostrophes are set by Mapbender for a valid syntax and should
actually lead to no error, but avoid mistakes...
You have activated the digitizer in version 1.2. in your system [2]?
[1]
https://doc.mapbender.org/en/quickstart.html#start-mapbender-in-the-developer-mode-app-dev-php
[2]
https://github.com/mapbender/mapbender-starter/blob/master/application/composer.json#L58
Best regards,
Charly
Mit freundlichen Grüßen
Charlotte Toma
GIS-Consultant
FOSS Academy Kompaktkurs "Winterschule 2019"
Grundwissen zum Aufbau von Geodateninfrastrukturen mit Open-Source-Software
https://foss-academy.com/kompaktkurse
Charlotte Toma
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 24
Fax: +49(0)228 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 22.01.19 um 19:08 schrieb nulu:
> Dear users,
> i have a problem regarding the copy function, described here:
> https://doc.mapbender3.org/de/functions/editing/digitizer.html#duplizieren-von-objekten
> Possible reason may be the apostrophe added to the on stament everytime i
> pass the code. See below.
> <http://osgeo-org.1560.x6.nabble.com/file/t384417/Unbenannt.png>
> Has anyone a idea how to solve this?
> Best regards,
> Lukas Nübel
> Sent from: http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
