[Mapbender-users] mapbender - increase automatic logout time
Charlotte Toma (WhereGroup) charlotte.toma at wheregroup.com
Wed Jul 24 06:19:43 PDT 2019
Hello Karsten,
you can use the parameter "cookie_lifetime" in the parameters.yaml
(app/config/parameters.yml in mapbender-folder).
The default-value is 3600 and means, that the user is logged out after
60 minutes. If you want to disable the logout so the user can stay
logged in as long as the browser remains open you can set this parameter
to 0. =
*cookie_lifetime = 0*
Documentation of symfony-parameter:
https://symfony-documentations.readthedocs.io/en/2.6/components/http_foundation/session_configuration.html#session-cookie-lifetime
Greetings
Charlotte Toma
WhereGroup
Am 24.07.19 um 14:12 schrieb karsten:
> Hi All,
> would anyone know how I can increase the time when a MapBender user
> will need to log into MapBender again.
> Some users reported having to log in after a very short time. I was
> thinking that there should be a parameter in php.ini but not sure
> which is the correct one to increase the time for automatic logout
> affecting MapBender.
> Is that done with the parameter session.gc_maxlifetime  ?
> Any hints how to solve this?
> Cheers
> Karsten
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
 Kompaktkurs Aufbau einer GDI mit Open-Source-Software
 FOSS Academy Sommerschule: 23. bis 27.09.2019
 https://www.foss-academy.com/kompaktkurse.html
Charlotte Toma
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 24
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20190724/1f4f6078/attachment.html>
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20190724/1f4f6078/attachment.key>
More information about the Mapbender_users mailing list
