[Mapbender-users] Mapbender v3.0.8.4 and PHP 7.1
Maelle Vercauteren
mavercau at ulb.ac.be
Wed Oct 2 23:49:31 PDT 2019
Hello,
It seems that contrary to what is noted in the documentation, PHP 7.1 is
also not supported
cf.https://doc.mapbender3.org/en/installation/systemrequirements.html#php-7
Indeed, the installation of mapbender (v3.0.8.3 and .4) did not succeed
following a non execution of the commands app / console (launched from the
file mapbender3).
The message returned in the terminal is as follows (in red) at each
launching of app/console doctrine:
[Symfony\Component\Debug\Exception\ContextErrorException]
Warning: "continue" targeting switch is equivalent to "break". Did you mean
to use "continue 2"?
And via symphony (http://localhost/mapbender3/config.php) you can see :
ERROR - Uncaught PHP Exception
Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route
found for "GET /_configurator/" (from "
http://localhost/mapbender3/config.php")" at
/var/www/mapbender3/vendor/symfony/symfony/src/Symfony/Component/HttpKernel/EventListener/RouterListener.php
line 179
: No route found for "GET /_configurator/" (from "
FYI, the same installation seems work with PHP 7.0
Kinds regards,
Maë//e
Maëlle VERCAUTEREN DRUBBEL
Coordinatrice du stage SIG Libres ARES
Département Géosciences, Environnement et Société
Université Libre de Bruxelles
Bureau: S.DB.6.143
CP 130/03
Av. F.D. Roosevelt 50
1050 Bruxelles
Belgique
Tél.: 02/650.68.14 Fax: 02/650.50.92
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20191003/59873238/attachment.html>
More information about the Mapbender_users
