[Mapbender-users] Mapbender v3.0.8.4 and PHP 7.1
Maelle Vercauteren mavercau at ulb.ac.be
Wed Oct 9 05:26:53 PDT 2019
Hello,
I just uninstalled everything, restarted my script with php7.1 and it works
fine, thanks for your help.
I am a bit puzzled because I am sure that I had installed only php7.1.
Here’s what I have in my terminal :
apt-get install apache2 libapache2-mod-php7.1 php7.1-php7.1 php7.1-php7.1
php7.1-php7.1-php7.1-php7.1 -sqlite3 sqlite3 php7.1-apcu php7.1-intl
php7.1-zip php7.1-mbstring php7.1-bz2 php7.1-pgsql
In my installation, the only difference was that I replaced php7.1 with 7.0
in this command to make it work.
However, it is true that in my base deposit I had php3; that's why I added
the ppa: ondrej / php before the installation. Maybe php3 was also
installed by another program on my computer, and doing the complete
uninstallation resolved the problem.
Kind Regards,
Maë//e
Le lun. 7 oct. 2019 à 09:17, David Patzke <david.patzke at wheregroup.com> a
écrit :
> Hi,
> are you sure you´re on Php 7.1 in your CLI.   Mapbender .8.4 works fine
> with Php 7.1. I just tested it. Furthermore, your error message is a known
> deprecation warning in Php 7.3.
> https://wiki.php.net/rfc/continue_on_switch_deprecation &
> https://github.com/doctrine/DoctrineORMModule/issues/579 .
> Could you run  "php -v" in your CLI and check the output version. Your
> Webserver and your CLI do not have to share the same version of Php.
> Cheers David
> On 03.10.19 08:49, Maelle Vercauteren wrote:
> Hello,
> It seems that contrary to what is noted in the documentation, PHP 7.1 is
> also not supported
> cf.
> https://doc.mapbender3.org/en/installation/systemrequirements.html#php-7
> Indeed, the installation of mapbender (v3.0.8.3 and .4) did not succeed
> following a non execution of the commands app / console (launched from the
> file mapbender3).
> The message returned in the terminal is as follows (in red) at each
> launching of app/console doctrine:
> [Symfony\Component\Debug\Exception\ContextErrorException]
> Warning: "continue" targeting switch is equivalent to "break". Did you mean
> to use "continue 2"?
> And via symphony (http://localhost/mapbender3/config.php) you can see :
> ERROR - Uncaught PHP Exception
> Symfony\Component\HttpKernel\Exception\NotFoundHttpException: "No route
> found for "GET /_configurator/" (from "
> http://localhost/mapbender3/config.php")" at
> /var/www/mapbender3/vendor/symfony/symfony/src/Symfony/Component/HttpKernel/EventListener/RouterListener.php
> line 179
> : No route found for "GET /_configurator/" (from "
> FYI, the same installation seems work with PHP 7.0
> Kinds regards,
> Maë//e
> Maëlle VERCAUTEREN DRUBBEL
> Coordinatrice du stage SIG Libres ARES
> Département Géosciences, Environnement et Société
> Université Libre de Bruxelles
> Bureau: S.DB.6.143
> CP 130/03
> Av. F.D. Roosevelt 50
> 1050 Bruxelles
> Belgique
> Tél.: 02/650.68.14 Fax: 02/650.50.92
> Mapbender_users mailing listMapbender_users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapbender_users
> Aufwind durch Wissen!
> Qualifizierte Open-Source-GIS-Schulungen
> bei der www.foss-academy.com
Bureau: S.DB.6.143
CP 130/03
1050 Bruxelles
Belgique
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20191009/b7affc13/attachment.html>
More information about the Mapbender_users mailing list
