[Mapbender-users] Coordinates utility
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue Jan 7 03:45:05 PST 2020
Hello Zsolt,
thanks for sharing your observations.
I had a look at my application and everythin works fine. Unfortunately I
can not reproduce your error.
Coordinates Utility should initialize independent from SRS SELECTOR and
SCALE SELECTOR.
Coordinates Utility gets the SRS information from the map-element. So
the map-element should be loaded before Coordinates Utility.
It looks like you can get your second application running properly with
SRS SELECTOR. Hope that is ok for the moment.
Astrid
Am 2019-12-10 08:39, schrieb Gal Zsolt:
> Hello list!
> I have two application where I need to use Coordinates Utility, find
> place on map from coordinates. The first was  made before I upgrade
> Mapbender to 3.0.8 and works OK.
> In the second application I try to use Coordinates Utility, but I get
> error message:
> YOUR ELEMENT ID 671 (WIDGET MAPBENDER.MBCOORDINATESUTILITY) FAILED TO
> INITIALIZE PROPERLY.
> After unsuccessful attempts to eliminate the error message  I add SRS
> SELECTOR to the application and the error disappear! The Coordinates
> Utility works fine. If I remove the SRS SELECTOR the error message
> reappear.
> In the first application I don't use SRS SELECTOR! But I use SCALE
> SELECTOR.
> I remove the SRS SELECTOR and add a SCALE SELECTOR in the second
> application and Coordinates Utility works fine.
> I reread Coordinate utility documentation but I don't find any
> reference about require to use SRS Selector or Scale selector with
> Coordinate utility.
> Have a nice day to everybody!
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
  Aufwind durch Wissen!
  Qualifizierte Open-Source-Schulungen
  bei der www.foss-academy.com
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Fon: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users mailing list
