[Mapbender-users] Search Rout
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Wed Jan 15 05:31:56 PST 2020
Hello Siline,
your configuration looks fine. Did you also try with a PostgreSQL table
(that should work for sure).
Please also check the developer mode to find out whether the connection
works fine.
http://server/mapbender/app_dev.php
With F12 it will show you if problems occur.
Empty cache.
Export web: app/console assests:install web
Astrid
Am 2020-01-15 10:12, schrieb Siline:
> Hi,
> I am trying to configure for search rout.
> on the search interface, I click on Search, but no result or any
> action.
> Please help?
> Thanks!
> Bellow is my configuration.
> config.yml
> db1_5:
> driver: %db1_5_database_driver%
> host: %db1_5_database_host%
> port: %db1_5_database_port%
> dbname: %db1_5_database_name%
> path: %db1_5_database_path%
> user: %db1_5_database_user%
> password: %db1_5_database_password%
> persistent: true
> charset: UTF8
> logging: %kernel.debug%
> profiling: %kernel.debug%
> parameters.yml
> parameters:
> database_driver: pdo_sqlite
> database_host: ~
> database_port: ~
> database_name: ~
> database_path: %kernel.root_dir%/db/demo.sqlite
> database_user: ~
> database_password: ~
> db1_5_database_driver: pdo_mysql
> db1_5_database_host: localhost
> db1_5_database_port: 3306
> db1_5_database_name: db1_5
> db1_5_database_path: ~
> db1_5_database_user: root
> db1_5_database_password: ~
> This is my configuration on search element:
> class: Mapbender\CoreBundle\Component\SQLSearchEngine
> class_options:
> connection: db1_5
> relation: line_test
> attributes:
> - line_id
> - line_ref_num
> - line_name
> geometry_attribute: line_geo
> form:
> line_ref_num:
> type: text
> options:
> required: false
> label: 'Line Number'
> attr:
> data-autocomplete: on
> compare: ilike
> results:
> view: table
> count: true
> headers:
> line_id: 'ID'
> line_ref_num: 'Line Number'
> line_name: 'Name'
> callback:
> event: click
> options:
> buffer: 100
> minScale: null
> maxScale: null
> styleMap:
> default:
> strokeColor: '#00ff00'
> strokeOpacity: 1
> fillOpacity: 0
> select:
> strokeColor: '#ff0000'
> fillColor: '#ff0000'
> fillOpacity: 0.8
> temporary:
> strokeColor: '#0000ff'
> fillColor: '#0000ff'
> fillOpacity: 1
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte Open-Source-Schulungen
bei der www.foss-academy.com
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
