[Mapbender-users] Search Router work only on develoment mode
David Patzke david.patzke at wheregroup.com
Mon Jan 27 22:49:36 PST 2020
Hi Siline,
if production and development mode behave differently it is mostly a
cache problem. Delete your prod cache and try again.
If this does not work, take a look into your prod.log (it´s in
app/logs/) there should be a clearer error message.
Cheers
On 28.01.20 02:52, Siline wrote:
> Dear All,
> I configured Search Router on my map. It works only on development
> mode(http://server/mapbender/app_dev.php).
> When go to the production mode (http://server/mapbender/app.php),
> the error is:
> "Oops! An Error Occurred The server returned a "500 Internal Server Error".
> Could you know what is the cause? and how to fix it?
> Best,
> Siline
> Sent from: http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open-Source-GIS-Schulungen
bei der www.foss-academy.com
More information about the Mapbender_users mailing list
