[Mapbender-users] error with app/consoledoctrine:database:create
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Thu Jul 2 23:17:59 PDT 2020
Hello Kartsten,
please try
app/console mapbender:config:check
https://doc.mapbender.org/en/customization/commands.html#app-console-mapbender-config-check
Looks like Mapbender can not create the connection to the database.
Is everything installed?
sudo apt install php-gd php-curl php-cli php-xml php-sqlite3 sqlite3
php-apcu php-intl openssl php-zip php-mbstring php-bz2
Try also to connect to your database via psql
psql -U mydbuser
(maybe create the database mapbender and try to connect)
psql -U mydbuser mapbender
Astrid
Am 2020-07-03 07:28, schrieb Härtel:
> Hi Karsten,
> is postgres extension for php correctly installed and active on the
> machine?
> Can you login and connect to any database from command line?
> Cheers,
> Connor
> Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org]
> Im Auftrag von karsten
> Gesendet: Dienstag, 30. Juni 2020 12:14
> An: 'Mapbender User List'
> Betreff: Re: [Mapbender-users] error with
> Hi David,
> thanks I tried but got same error :(
> I also reinstalled postgres (now version 9.6 ) to no avail
> Any other hints ?
> Cheers
> Karsten
> From: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org]
> On Behalf Of David Patzke
> Sent: Tuesday, June 30, 2020 02:27
> To: mapbender_users at lists.osgeo.org
> Subject: Re: [Mapbender-users] error with
> Hi Karsten,
> can you try 127.0.0.1 instead of localhost. localhost is not treaten
> the same as 127.0.0.1 in the default pg_hba.conf.
> David
> On 30.06.20 11:23, karsten wrote:
>> Hi All,
>> I am trying to install mapbender 3.08 (also tried 3.0.5) on an
>> Ubuntu 16 server
>> I have tried the versions from git the zip and the *.gz version , I
>> can run and connect to teh mapbender installation when using the
>> demo.sqlite file Db but when I am trying to use postgres as the
>> database - No matter what version I used I am always getting the
>> following error when running app/console doctrine:database:create
>> user1 at terraxyz:/var/www/mapbender# app/console
>> [Doctrine\DBAL\Exception\ConnectionException]
>> An exception occured in driver: SQLSTATE[08006] [7] timeout
>> expired
>> [Doctrine\DBAL\Driver\PDOException]
>> SQLSTATE[08006] [7] timeout expired
>> [PDOException]
>> This is in my parameters.yml
>> database_driver: pdo_pgsql
>> database_host: localhost
>> database_port: 5432
>> database_name: mapbender
>> database_path: ~
>> database_user: mydbuser
>> database_password: supersecret
>> mailer_transport: smtp
>> mailer_host: localhost
>> mailer_user: ~
>> mailer_password: ~
>> There are no messages opr errors in the postgresql.log file ...
>> Any ideas what si wrong and how to fix it ?
>> Cheers
>> Karsten Vennemann
>> Terra GIS LTD
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> Aufwind durch Wissen!
> Qualifizierte Open-Source-GIS-Schulungen
> bei der www.foss-academy.com [1]
> Links:
> [1] http://www.foss-academy.com
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Jetzt neu: Webinare und Online-Schulungen
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
