[Mapbender-users] Zoom to layer in layer tree not working properly
Armin Retterath
armin.retterath at vermkv.rlp.de
Mon Jun 8 20:57:42 PDT 2020
hi sajid,
maybe the bbox of the layers are not handled consistently - here are the crs related extracts from the capabilities docs:
wms 1.1.1
<SRS>EPSG:4326</SRS>
<LatLonBoundingBox minx="75.61699436455098" miny="16.19036450771302" maxx="77.30248329850956" maxy="17.47232605225013"/>
<BoundingBox SRS="EPSG:4326" minx="75.61699436455098" miny="16.190364507713397" maxx="77.30248329847431" maxy="17.47232605225013"/>
wms 1.3.0
... many crs ...
<CRS>CRS:84</CRS>
<EX_GeographicBoundingBox>
<westBoundLongitude>75.61699436455098</westBoundLongitude>
<eastBoundLongitude>77.30248329850956</eastBoundLongitude>
<southBoundLatitude>16.19036450771302</southBoundLatitude>
<northBoundLatitude>17.47232605225013</northBoundLatitude>
</EX_GeographicBoundingBox>
<BoundingBox CRS="CRS:84" minx="75.61699436455098" miny="16.19036450771302" maxx="77.30248329850956" maxy="17.47232605225013"/>
<CRS>EPSG:4326</CRS>
<CRS>CRS:84</CRS>
<BoundingBox CRS="EPSG:4326" minx="16.190364507713397" miny="75.61699436455098" maxx="17.47232605225013" maxy="77.30248329847431"/>
you see, that the axis order in wms 1.3.0 is switched fom lat/lon to lon/lat - this is defined in the ogc standards.
you use wms 1.1.1 for the basemap and wms 1.3.0 for your own resource - therefor mapbender will switch the extents i think. test to register your service with wms version 1.1.1 and it will work. maybe you can register both services with version 1.3.0 and it may also work ;-) .
best regards
armin
> Sajid Pareeth <spareeth at gmail.com> hat am 8. Juni 2020 um 23:43 geschrieben:
> Hi list
> I have deployed a mapbender application with many geoserver based WMS
> layers listed.
> But the "zoom to layer" function under each layer is not working properly.
> The layer is zoomed to some where else. It seems, the BBOX x and y are
> swapped when zoomed to layer.
> Here is a demo app with one of my layer (bdry) under layerset called ABC,
> displayed on top of two other base WMS layers.
> http://www.wa-urmia.org/mapbender/application/test
> The geoserver link to my wms layer is:
> http://188.40.139.182:8080/geoserver/nlbc_bdry/wms
> I am using the latest version of mapbender 3.0.8 and geoserver version is
> 2.17.0
> Can anyone help me with this?
> Thanks in advance
> Regards
> Sajid
> Sajid Pareeth, Ph.D
> Researcher – Remote sensing
> Water Science and Engineering Department
> UNESCO-IHE Institute for Water Education
> Delft, The Netherlands
> Phone No.: +31 (0)15 215 2395 <+31%2015%20215%201825>
> Skype ID: spareeth
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
