[Mapbender-users] error with app/console doctrine:database:create
David Patzke
david.patzke at wheregroup.com
Tue Jun 30 02:27:13 PDT 2020
Hi Karsten,
can you try 127.0.0.1 instead of localhost. localhost is not treaten the
same as 127.0.0.1 in the default pg_hba.conf.
David
On 30.06.20 11:23, karsten wrote:
> Hi All,
> I am trying to install mapbender 3.08 (also tried 3.0.5) on an Ubuntu
> 16 server
> I have tried the versions from git the zip and the *.gz version , I
> can run and connect to teh mapbender installation when using the
> demo.sqlite file Db but when I am trying to use postgres as the
> database - No matter what version I used I am always getting the
> following error when running app/console doctrine:database:create
> user1 at terraxyz:/var/www/mapbender
> <mailto:user1 at terraxyz:/var/www/mapbender># app/console
> [Doctrine\DBAL\Exception\ConnectionException]
> An exception occured in driver: SQLSTATE[08006] [7] timeout expired
> [Doctrine\DBAL\Driver\PDOException]
> [PDOException]
> This is in my parameters.yml
> database_driver: pdo_pgsql
> database_host: localhost
> database_port: 5432
> database_name: mapbender
> database_path: ~
> database_user: mydbuser
> database_password: supersecret
> mailer_transport: smtp
> mailer_host: localhost
> mailer_user: ~
> mailer_password: ~
> There are no messages opr errors in the postgresql.log file ...
> Any ideas what si wrong and how to fix it ?
> Cheers
> Karsten Vennemann
> Terra GIS LTD
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open-Source-GIS-Schulungen
bei der www.foss-academy.com
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20200630/aaf3a238/attachment.html>
More information about the Mapbender_users
