[Mapbender-users] app_dev.php is not opening
SL srun_siline at yahoo.com
Thu Mar 19 19:27:11 PDT 2020
Hello Astrid,
I had the same problem which takes a long time to load app_dev.php and css
doest not load as well.
The error on browser:
Request
URL:http://localhost/mapbender/app_dev.php/application/manager/assets/css
Request Method:GET
Remote Address:127.0.0.1:80
Status Code: 500 Internal Server Error
Version:HTTP/1.1
Referrer Policy:no-referrer-when-downgrade
The error on error logs:
[2020-03-20 03:01:25] request.CRITICAL: Uncaught PHP Exception
Symfony\Component\Process\Exception\ProcessTimedOutException: "The process
""E:\mapbender\vendor\wheregroup\sassc-binaries\dist/sassc.exe"
"--load-path" "\\" "--style" "nested" "--load-path"
"E:\mapbender\app/../mapbender/src/Mapbender/CoreBundle/Resources/public/sass"
"--load-path" "E:\mapbender\app/../vendor/igosuki/compass-mixins/lib"
"--load-path" "E:\mapbender\app/../web" "C:\Windows\Temp\assD79.tmp""
exceeded the timeout of 60 seconds." at
E:\mapbender\vendor\symfony\symfony\src\Symfony\Component\Process\Process.php
line 1193 {"exception":"[object]
(Symfony\\Component\\Process\\Exception\\ProcessTimedOutException(code: 0):
The process
\"\"E:\\mapbender\\vendor\\wheregroup\\sassc-binaries\\dist/sassc.exe\"
\"--load-path\" \"\\\\\" \"--style\" \"nested\" \"--load-path\"
\"E:\\mapbender\\app/../mapbender/src/Mapbender/CoreBundle/Resources/public/sass\"
\"--load-path\" \"E:\\mapbender\\app/../vendor/igosuki/compass-mixins/lib\"
\"--load-path\" \"E:\\mapbender\\app/../web\"
\"C:\\Windows\\Temp\\assD79.tmp\"\" exceeded the timeout of 60 seconds. at
E:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\Process\\Process.php:1193)"}
Sent from: http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
More information about the Mapbender_users mailing list
