[Mapbender-users] select features with polygon
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Fri Mar 20 04:52:49 PDT 2020
Hello Hardy,
FeatureInfo is a WMS request and only works with single points. In
addition you can not select any objects in the raster-resualt of an
getmap-request.
Have a look at the digitizer, it might work for you. Digitizer does not
necessarily edit data, you can configure it only to show gemoetries and
attributes.
For digitizer the data has to be stored in a database you have access
to. At least you could use a WFS via fdw in postgres.
Jörg
Am 20.03.20 um 12:20 schrieb Hardy:
> Hi all,
> is there a way to select multiple features using a polygon and show result
> as feature info?
> Regards
> Hardy
> Sent from: http://osgeo-org.1560.x6.nabble.com/mapbender-users-f4220788.html
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Viele Grüße,
Jörg Thomsen
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74
Fax: +49 (0)30 / 5130 278 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the Mapbender_users
