[Mapbender-users] app_dev.php is not opening
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Mon Mar 23 05:21:47 PDT 2020
Hello,
in your log it says:
>> \"C:\\Windows\\Temp\\assD79.tmp\"\" exceeded the timeout of 60
>> seconds. at
So please check whether your Apache user can write into this directory.
Astrid
Am 2020-03-20 12:35, schrieb Jeff McKenna:
> Hello,
> For Windows users we solved this by leveraging many tricks to speed up
> the load for the MS4W distribution, such as the OPcache PHP extension
> etc. You can test the speed on the official demo server at
> https://ms4w.dev/mapbender/app.php/ or download MS4W from
> https://ms4w.com
> Hope that helps,
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> https://gatewaygeomatics.com/
> On 2020-03-19 11:27 p.m., SL wrote:
>> Hello Astrid,
>> I had the same problem which takes a long time to load app_dev.php and
>> css
>> doest not load as well.
>> The error on browser:
>> Request
>> URL:http://localhost/mapbender/app_dev.php/application/manager/assets/css
>> Request Method:GET
>> Remote Address:127.0.0.1:80
>> Status Code: 500 Internal Server Error
>> Version:HTTP/1.1
>> Referrer Policy:no-referrer-when-downgrade
>> The error on error logs:
>> [2020-03-20 03:01:25] request.CRITICAL: Uncaught PHP Exception
>> Symfony\Component\Process\Exception\ProcessTimedOutException: "The
>> process
>> ""E:\mapbender\vendor\wheregroup\sassc-binaries\dist/sassc.exe"
>> "--load-path" "\\" "--style" "nested" "--load-path"
>> "E:\mapbender\app/../mapbender/src/Mapbender/CoreBundle/Resources/public/sass"
>> "--load-path" "E:\mapbender\app/../vendor/igosuki/compass-mixins/lib"
>> "--load-path" "E:\mapbender\app/../web" "C:\Windows\Temp\assD79.tmp""
>> exceeded the timeout of 60 seconds." at
>> E:\mapbender\vendor\symfony\symfony\src\Symfony\Component\Process\Process.php
>> line 1193 {"exception":"[object]
>> (Symfony\\Component\\Process\\Exception\\ProcessTimedOutException(code:
>> 0):
>> The process
>> \"\"E:\\mapbender\\vendor\\wheregroup\\sassc-binaries\\dist/sassc.exe\"
>> \"--load-path\" \"\\\\\" \"--style\" \"nested\" \"--load-path\"
>> \"E:\\mapbender\\app/../mapbender/src/Mapbender/CoreBundle/Resources/public/sass\"
>> \"--load-path\"
>> \"E:\\mapbender\\app/../vendor/igosuki/compass-mixins/lib\"
>> \"--load-path\" \"E:\\mapbender\\app/../web\"
>> seconds. at
>> E:\\mapbender\\vendor\\symfony\\symfony\\src\\Symfony\\Component\\Process\\Process.php:1193)"}
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Astrid Emde
WhereGroup GmbH
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_users
